'80 F100 tags help
Old 05-26-2011, 04:03 PM
genseeker's Avatar
genseeker
genseeker is offline
'80 F100 tags help
Just bought 1980 F100. Supposed to be only 3 previous owners. I need help with the VIN & door tag.
VIN: F10ENHD1099
DOOR TAG STUFF:
WB - 117
BODY - AA
TRANS - J
AXLE - 13
DSO - 1980
EXT PAINT - 6D
I also have the original warranty ID card so I know the original purchasing company. It is 2 lines of info:
F10ENHD1099 9 6D 25
F100 4 13 J
The truck in an inline 300 6cyl auto but I don't know which tranny. Truck is in amazing shape with only minor rusted out areas, mostly over wheel wells. Bench seat is ruined but I can recover it myself. I did look under the hood and it had a "Duraspark" instead of ignition control module.
Is this a 2bbl carb setup and if not, can I put a 2 bbl or a 4bbl on it? Shortbed and solid rear window. Door locks aren't visible, instead they are slides down on the door panel itself.
Would love to get a Carfax but on disability, so can't afford it right now. Saw the info on ordering a build sheet so will do that tomorrow but anything I can find out now is great.
It's replacing my '84 F150 that was wrecked in March. Frame got twisted so she was a total loss for me.
Thanks, Tabitha
Old 05-26-2011, 04:22 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
F10 = F100
E = 300 CID I6 1bbl
N = Norfolk, Va assembly plant
HD1099 is the build number From this, I am guessing it is 12/79-1/80 build date.
Door tag stuff (what I know)
WB 117 = shortbed (6ft)
Axle 13 = 2.75 ratio
