Parting out 96 F350 CCLB 4x4 PSD
Category: Accessories
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Item Condition: WA
Shipping Information: Item can be shipped
Engine: Part suitable for diesel truck
AC condensor SOLD
Brake master cylinder $30
Brake booster $30
Alternator $50
Vacuum pump SOLD
Degas bottle (1 mounting tab broken but the bottle itself appears ok) $10
Underhood fuse box/wiring SALE PENDING
CA emissions PCM, calibration code MIF6 $150
Dash assembly- no gauges, bezel, wiring, or dash pad $250
Aluminum brace for the dash on the driver's side $20
Throttle pedal assembly (may keep as a spare) $150
Interior plastic trim pieces - make offer
Door panels (would like to sell as a set if possible) SOLD
Window motors SOLD
Door lock actuators SOLD
Door glass- all except driver's side front $30 each
Wing window assemblies SOLD
Rear bench seat $200
Rear sliding window $100
Interior cab lights SOLD
3rd brake light $10
Rear end- brakes good, 4.10LS $250
Rear springs $100
Passenger rear door $250
8' bed- damage on driver's side only, not sure if it would be worth having a new bed side welded on or not. Make offer
If it's not mentioned above its either sold, no good, or something I want to keep but feel free to ask if there's something you're after. Prices are OBO, shipping will be actual cost.
More stuff...
AC compressor SOLD
Stock OBS turbo/pedestal $300
Good AB injectors SOLD
Long block $1000
Reman 15° HPOP SOLD
Right tail light $20
Steering shaft (between column and box) SALE PENDING
Front and rear fuel tanks $100 each
Selector valve SOLD
AC compressor SOLD
Long block $1000
Reman 15° HPOP SOLD
Selector valve SOLD
Yes the glass will fit your truck, which glass do you need? Depending on your location shipping might be a deal breaker, and there's a good chance of glass getting damaged in transit.
Brian I'm happy to help you out but shipping that window scares me... I'll look into it though.
Up pipes should be ok but I'd have to check.
Valve covers are staying with the motor.
I shipped some side window just fine. Wrap them in cardboard. Get a box plenty bigger than the window. Fill it half way with packing peanuts. Place the cardboard wrapped window in. More peanuts. I even slid some extra pieces of cardboard between the edges of the glass and the box for extra stiffness.
Mark Glass on the box all over and Fragile stickers. It will be fine.
I still have the vent windows it was the door glass that I shipped that way.
You will be fine Chase
