Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 05-22-2011, 05:04 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Garage is empty, add now
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
Need help with 7.3L powerstroke. anyone have scanner
I am in Trenton
I bought 00 F350 7.3L so have issues with run rough and hard start.
Engine light is ON so I tried my scanner it say nothing codes on but there engine light ON.
PO replace so many parts on engine that confused me. On quick rev there TONS blue smoke but if you do slow rev almost no smoke or little blue smoke.
Very hard start. Have 1 bad glow plugs.
__________________
Sorry for my bad grammar.
Currently drive 2000 f350 7.3L XL 4wd auto. mpg vary 15-17.
1999 F250 5.4L 2wd 5.4L auto with over 246K miles. Got used 5.4L with 100K miles. Need find motivation to install 5.4L.
  #2 (permalink)
Old 05-26-2011, 12:08 AM
jimmyv13 jimmyv13 is offline
jimmyv13 is starting off with a positive reputation.
Jim Veillette
I have an SCT, how far away are we? I'm fairly new to the area.
__________________
2005 F-250 Lariat CC FX4 6.0L
4" MBRP Turbo Back*High Idle*Blue Spring*Updated Stand Pipes, Dummy Plugs*SGII w/Blendmount*Sinister Coolant Filter*SRL*'10 Tailgate*2" level*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*4" Rear Blocks
  #3 (permalink)
Old 05-26-2011, 07:01 AM
craftsmangary's Avatar
craftsmangary craftsmangary is offline
1997 Ford F-350
craftsmangary is starting off with a positive reputation.
Is it drivable? What has been done to it? How many miles? If the CEL is on you have codes. If the PO was throwing parts at it he must have been guessing, and that gets expensive and usually causes more problems.
If you can get it to me I have scanners that can do a buzz test and cylinder contriburion test, and I'm in South Lyon
  #4 (permalink)
Old 05-26-2011, 07:59 AM
SDElwood's Avatar
SDElwood SDElwood is offline
In corner drinking beer.
2000 Ford F-350
SDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud of
https://www.facebook.com/mike.blackport
Makes me wonder if the valve cover wiring harness has some goofs. Not too hard to check and it is a beer drinking sport.
__________________
Mike -
2000 4x4 CC LB F-350 7.3L SuperChips Flashpaq, 4" turbo back exhaust, 6637.
Quote:
Originally Posted by Toyman View Post
Dude you get thirsty at mid swallow of your beer, don't hide it.......
  #5 (permalink)
Old 05-26-2011, 08:52 AM
I end order AE scanner but everybody live far away.
I don't trust this truck to be on highway. It will drive but sometime you push more on gas it POUR BLACK smoke.
It have very bad hesitance and shake when Rev.
It only had 210K miles. Everybody told me it low compression I don't believe because it run too good at idle. Have 8 dead glow plugs.
CEL is on when crank and run. I am going check that truck with AE scanner today. Just got AE last night.
__________________
  #6 (permalink)
Old 05-26-2011, 09:11 AM
1997 Ford F-350
Was a compression test done with a guage, if not it a guess......... and most times a guess is wrong. With 210k the original injectors will be near the end of there life cycle. Post the codes you get.
  #7 (permalink)
Old 05-26-2011, 09:17 AM
Quote:
It guess because it idle very good for 210K miles. But it misfire shake when in gear.
Will go get codes in couple hours. Truck in Monroe.
__________________
  #8 (permalink)
Old 05-26-2011, 01:27 PM
Got new codes again
P1280
P1293
P1284
Can't rev anymore or it blow smoke badly.
I look at ICP connector it been cover in oil.
__________________
  #9 (permalink)
Old 12-16-2011, 09:49 AM
tlb22 tlb22 is offline
tlb22 is starting off with a positive reputation.
I have a 2003 F350 dually i bought off a friend. it does the exact same thing. if i start it everyday it is ok, but just ok, still have to run for a while before it runs good. if you dont let it warm up for a long time and you try to drive it, it viberates very bad at times. no matter how hard you press the peddle the responce can very from not much when cold, to normal when ran a while. a while being 20 min, maybe longer. I used my dads edge programmer to adjust increase HP and it did help, but not enough. I unplugged the injector harness one at a time while running and when i unplugged the passenger side it died, so i knew my rough "running/idle" is mostly from the driver side. i replaced the injector harness as they are known to burn up. Still rough run/idle. it appears to me that i have an injector or multiple injectors bad on the drivers side. given i have 260,000 miles they are all probably limping along. given the rough starts i would guess injector O rings are bad allowing fuel to leak off. O rings may by time, but limited time. I hate to purchase 8 new injectors. any one have any advice? used to be able to purchase rebuild kits for them, can you still and where? anyone have any experience with aftermarket injectors? will an injector buzz test confirm my thoughts about needing injectors 100%? I will pass along anything i discover. my last thought is, can a person take the valve cover off and unplug one injector at a time to see if there is a performance difference? i know oil will go everywhere, but does anyone see a negative affect this would have. then i could pin point the exact injectors and just replace them for the time being, before i replace them all. test like spark plugs on a gas car. if no performace difference when unplugged then that one(s) are bad.
  #10 (permalink)
Old 12-16-2011, 10:30 AM
Mine had bad PCM, 6 bad injectors. They work great when it warm up. Cold it still miss and rough. Now it running great but tiny rough but it Michigan winter here.
Cheapest reman injectors I trust. Riffraff Diesel: Stock Rebuilt Injectors
__________________
  #11 (permalink)
Old 12-20-2011, 12:10 PM
officer131 officer131 is offline
officer131 has a good reputation on FTE.officer131 has a good reputation on FTE.
P1280 ICP Circuit Out of Range Low.
p1293 High Side Open Bank No. 1 (Right)
p1284 ICP Failure - Aborts KOER/CCT Test
sorry came into this thread just now. These are coddes from guzzles website. Welcome to guzzle's Diagnostic Trouble Code list Web Page
__________________
AL,
02 Ex. LT 7.3 diesel. 4" SS 409 MBRP. AFE stage 2 w/pro guard air intake. DP Tuner F6: N/S, Stock, 80e, 120r, 80t, high idle. CCV. Autometer Cobalt gauges Boost, Pyro, Trans, Fuel Press., Oil temp, Volts. Kenwood KVT-512. Rear DVD headrest. F-650 dash. Viair extreme duty compressors. ORU roofrack w/ 8 PIAA ATP, and PIAA 1500 rear lights.
  #12 (permalink)
Old 12-22-2011, 12:50 PM
RickBraden RickBraden is offline
RickBraden is starting off with a positive reputation.
I live very closr to you
I'm within 5-6 miles of you. I have Scangauge 2, Edge Evolution CTS, & Auto Enginuity for the Ford stuff. Let me know if I can help you out. I'd be happy to helip you out if I can.
__________________
'04 F250, 50 gallon fuel tank, Pre-luber, by-pass oil filtration, 4" exhaust with down-pipe, Only Rotella 5w-40 full syn.
Tags
1997, 73, 73l, diesel, hard, p1284, performance, powerstroke, rev, scanner, scanning, sct, shakes, start, tuner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
