Calling all y blockers! Need some help and advice for my f100
Just have some questions. Do any of you daily drive your y block? I've heard from some people they will run forever and from others they are boat anchors and have an oiling problem. My truck is already setup for a y block so I would like to just drop one in but the bad overviews scare me. Doing a restoration( not frame off money is not there for that) and would like her to be reliable and my daily driver. So how do the y blocks compare to say like a 302 or 289 in reliability?
They are good old engines,i have three. Oiling was a problem they have for the upper part of the engines. Very important to keep clean oil in them as it helps with that oiling problem . There is a add on oiler kit for them,but i removed mine 20 years ago when i had it rebuilt and just kept the oil changed regular . They have solid lifters ,so you have to keep them adjusted if you want to make it last a long time. You might want to check out the Y-block forums here on F T E ,lots of information and help there.
I have two Y-blocks. They run great. I ran a bottle of slick 50 through my first one in 1993 because some of the push rods were dry indicating no oil flow. A week later I checked and all of the push rods were getting oiled.
The old generation of oil was not as forgiving as oil today. I run 10w-30 year round and it works great. Good luck, Jag
Oh go for the Y block!! Those were great engines. As long as you are getting oil up there you will love it! They do sound awesome and have plenty of power. They do start easy. I have a 54 f600 that I will soon turn into a dump truck. I start it up every couple months and it never fails me.
Psmith1951
08-12-2014 05:39 PM
thendrix
18
07-15-2011 11:07 AM
Greg Bockelman
11-15-2005 04:28 PM
