I was curious if anyone knew what the factory weight ratings of the f150 were. I have a 90 f150 extended cab longbed. I was also wondering how much it weighs. I went to register the truck and they asked. All I could find quick was 98 specs so I told them 5020lbs. Close enough I hope. I'll have to find a set of scales. I can't imagine it is that light. My darn Explorer weighed 5200lbs with my tools in it.
Thanks guys.
Curb weight of your truck is right around 5000lbs, my ext-cab 4x4 comes in at just a hair under 5k. There is no way your Explorer weighed that much unless you had 1000lbs of tools in it.
The empty weights and max laden weights for each axle are listed on the door sticker. As a general rule, empty weight refers to the vehicle with a full tank of gas and no passenger/driver.
