Getting ready to do the exaust so I got a cat question
The question is a simple one. To cat or not to cat, that is the question.
I'm sure I'll lose some back pressure and that will hurt my low end torque, but will it be enough to be detrimental? Are there any other issues I need to worry about.
I'd like to hear both sides. If you replaced yours, why. If you removed your, why.
First answer is a simple one too, in regards where you live and whether you have to get an emission inspection. Here in certain counties in PA, they won't even do a regular safety inspection untill you pass the emission test. They also do a visual inspection to verify all components are present. No emission = no registration.
I just put a new WYE pipe/converter assembly on my '93 this weekend. In all honesty, the new cats are pretty small and free flowing, I think. Unless you've modified your truck to take advantage of a free flowing exhaust, you may cause more problems since the truck is calibrated to work with the backpressure. The WYE/converter was also pretty cheap at $269.
Also, an air tube comes out of the new cat and goes up into the emission system. If you disable that, you may force a constant check engine light.
I have a nice Gibson cat back stainless steel dual exhaust system that makes the 302 sound quite nice. They claim a modest horsepower increase. I can't feel it though.
I have ordered a new Y-pipe and got the one with cats. Here in West Virginia there arent any emission tests, however they do a visual inspection during the safety inspection. They will not pass you and you cant get a new sticker. I don't think that it'll hurt your truck to have a newer cat on there.
From your description then, I dont think you'd have anything to lose by putting a new cat on. You have to really be moving some air for a cat to restrict your power. Look at all the new sports cars, they all have cats and are pushing out over 400 hp. I'd do a good set of headers and a new y-pipe, the factory one sucks.
Up here we dont have inspections and if I have to replace the exhaust I leave the cats out. I view free flowing exhaust as a modification, and a engine that gets rid of exhaust easier, is more efficient.
That being said if I had to throw cats on, im sure the high flow type ones would be better then all the old stock ones I am used to pulling off.
You wont even hear your exhaust with cats, I cut everything but the front cat off, and it made absolutely no difference, except for a little more of a ballsy sound at full throttle. Now ive got longtubes and true duals to cherry bomb turbos, and its still a fairly quiet setup considering what I have
