Leaking front axle
Old 05-16-2011, 06:59 PM
ztodd377's Avatar
ztodd377
ztodd377 is offline
Leaking front axle
So I just replaced my balljoints in both sides a couple of weeks ago and replaced o-rings and wheel seals at the same time. Came out after work today and there's diff fluid leaking out the en of the axle housing on the drivers side. Any suggestions on fixing this?
Old 05-16-2011, 07:34 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
unfortunatly when you slid the axle out and then back in, you may have damaged the inner seal.... which sucks
you will need to take it all back apart including the front cover, remove the diff and replace the seals.
and you might as well replace both while you have it opened up
OR
it just could be seeping out and not a big deal..but not likely
i usually grease the end of the axle where the seal rides and the splines, helps it slide over the lip of the seal without damage.
let us know how it turns out
Old 05-16-2011, 08:01 PM
ztodd377's Avatar
ztodd377
ztodd377 is offline
So there's a seal internal to the diff? If so, can the seals be replaced without taking the gears out of the diff?
Old 05-16-2011, 10:44 PM
ztodd377's Avatar
ztodd377
ztodd377 is offline
Does anyone have part numbers for these seals and possibly a diagram of location and placement.
Old 05-16-2011, 11:03 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
of American machinists
There was a thread on this yesterday ,let me see if I can find it
Old 05-16-2011, 11:08 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
https://www.ford-trucks.com/forums/9...placement.html
and a nice link for the tool that is used to install the seals
4x4tools
sillyjt
1999 to 2016 Super Duty
08-07-2012 11:39 AM
1950gmcelc
03-24-2009 03:26 PM
THE KING
1978 - 1996 Big Bronco
12-17-2007 06:04 PM
Jspafford
06-16-2007 01:11 PM
grelch
04-07-2007 12:33 PM
Quick Reply: Leaking front axle
