Royal prple turned to sludge
I was running Royal Purple and it turned to sludge. My check engine light came on, bronco died. it sat I started it up drove it home about 1 mile and replaced oil pump. Now it wont turn over like it ceased up. Guy at autozone told me if there isnt grinding then i need to run diesel fuel to clear the sludge. Has any one had this problem or heard this solution?
yea get a fresh battery on there. clean you ground and positive bat cables also.
I would run some Delo 15w-40 or Rotella oil thru the motor with a purolator or motorcraft filter. run the motor for a good 500 miles and change the oil/filter and put another 6 quarts of delo/rotella thru it for a normal 3000k and then run what ever you want.
the delo/rotella are a high detergent and will get the inside cleaned up good. not to mention the high zinc is good for the motor. I run the delo exclusivly only my newly built 357.
jswford
1983 - 2012 Ranger & B-Series
10-31-2014 10:59 AM
Undertheoaks
38
04-07-2014 01:21 AM
