manifold to downpipe bolt ?
Old 05-16-2011, 10:56 AM
justtin00j's Avatar
justtin00j
justtin00j is offline
I've been searching but can't find the answer. How does the exhaust manifold attach to the downpipe. It is a 1985 300 carb'd. I took a quick glance and noticed the previous owner has a C-clamp holding part if it together. Is it just a stud attached to the manifold and a bolt in the downpipe side or can I use a new bolt and nut? Thanks.
Old 05-16-2011, 11:21 AM
Ranger GT2's Avatar
Ranger GT2
Ranger GT2 is offline
If you are asking about how the exhaust attaches to the exhaust manifold then there should be 2 studs that screw into the exhaust manifold and the exhaust pipe flange goes onto the studs and has a nut on each stud to keep it secure.
If one is missing then the stud is broken off and would have to be removed and a new one installed or a different exhaust manifold would have to be put on.
If you mean something else please post a picture of it.
Old 05-16-2011, 12:11 PM
justtin00j's Avatar
justtin00j
That explains it spot on. Guess I'll be looking for a new manifold.
Old 05-16-2011, 06:20 PM
5_labsownus's Avatar
5_labsownus
5_labsownus is online now
Received 1,525 Likes on 1,423 Posts
drop the exhaust pipe from the manifold and see if the stud is missing or broken. It can be replaced or if broken drilled, tapped and new stud installed.
Arizona84F150
04-09-2017 09:05 PM
bluemtn95ford
01-05-2016 06:38 PM
Ford79
01-04-2009 07:42 AM
coker0290
Exhaust Systems
10-01-2004 10:42 PM
Quick Reply: manifold to downpipe bolt ?
