1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2003 f250 fuel sending unit...
Old 05-15-2011, 05:46 PM
p36uranium's Avatar
p36uranium
p36uranium is offline
My fuel gauge is pinned on full and will not move off of it. Any Ideas what it may be.. are there any common problems with the sending units.. thank you
Old 05-15-2011, 05:56 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
try a couple of big bottles of fuel system treatment/cleaner..
sometimes varnish can gum up the float and cause the sender to show either no fuel or beyond full..
if that dont work, then you might have a bad sender, but they usualy will show below ZERO fuel when they go bad, not the other way...
Old 05-15-2011, 06:58 PM
Rongold's Avatar
Rongold
Rongold is offline
FUEL GAUGE
Try banging on the bottom of the tank with a rubber hammer. If the float on the sending unit is stuck, this just might free it up.
RON
Old 05-15-2011, 07:19 PM
p36uranium's Avatar
p36uranium
thank you for your help, i will try both
my 66
06-18-2014 09:59 PM
raye321
08-11-2013 03:06 PM
2004Lightning
02-09-2013 03:03 AM
locomotivebreath
01-25-2011 07:06 PM
Reelman1a1
12-18-2006 10:13 AM
Quick Reply: 2003 f250 fuel sending unit...
