EXCURSION IN TANK MOD/DROPPING FUEL TANK
05-15-2011, 09:53 AM
on
I did a search on in tank mod to EX ,hoping to find out information on how to drop fuel tank.
I see 4 large bolts that hold skid plate in place.
After I take the 4 bolts out, will the skid plate /fuel tank come out together?
If not then are there bands that hold the fuel tank in?
Has anyone done the in tanks mod on there EX?
05-15-2011, 10:24 AM
I did some other mods to my fuel system and pulled the tank. The 4 bolts you see(front/back) mount the tank and skid plate. They'll both come down together.
05-15-2011, 11:44 AM
on
Thanks for the reply.
seems to be straight forward?
Support tank at skid plate (floor jack)
Remove 4 bolts
Lower jack
Disconnect fuel lines/fuel inlet filler hose
Pull tank out?
Any thing else I over looked?
Thanks again
05-15-2011, 01:23 PM
Lower tank a little to give more room to disconnect lines?
Unhook fuel level sender. On my cabchassis F350 (rear tank like X) there was a connector out in front of tank.
05-15-2011, 01:47 PM
on
05-15-2011, 03:17 PM
Quote:
Originally Posted by
01EX
No smoking!
05-15-2011, 05:27 PM
on
Hutch mod? Do these tanks need the hutch mod? I've never heard of them needing it and Mine fills fast and all the way up.
Unless you're doing a different mod?
06-27-2012, 07:11 PM
i think they do cause mine died at 1/4 tank a month or so ago! so im gonna do the mod. thanks to TRDLTLY for pointing this thread out to me.
06-28-2012, 12:45 AM
locknload223
Hutch mod? Do these tanks need the hutch mod? I've never heard of them needing it and...
Yep, they do. The Ex tanks are no different than the 250/350 tanks except they hold more than the truck tanks.
Quote:
Mine fills fast and all the way up .
You're thinking of the Harpoon Mod that allows the tank to be filled faster.
Welcome to guzzle's In-tank Harpoon Mod Web Page
The Hutch Mod (
Welcome to guzzle's In-tank Hutch Mod Web Page ) eliminates air before the fuel pump and adds a pre-pump filter setup since the mixing chamber screen is removed when doing the Hutch Mod.
I've done both to my Excursion.
Stewart
06-28-2012, 01:12 AM
I suggest having a second person help you, its a PITA for one person plus you cut your time in half. It took me 12 hrs start to finish with one person.
06-28-2012, 01:13 AM
I just relized this thread is over a yr old
06-28-2012, 01:22 AM
robbragiel
Yeah, but it was left open-ended so it needed to be updated with answers.
Stewart
bives
1999 to 2016 Super Duty
37
04-29-2017 04:22 PM
Corndwg01
04-21-2017 09:10 PM
blacklabel2121
05-31-2016 11:07 AM
7.3 Ex
07-30-2009 02:51 AM
92mnfordtrk
44
10-11-2008 01:15 AM
2000 ,
capacity ,
dropping ,
excrusion ,
excursion ,
f250 ,
f350 ,
ford ,
fuel ,
gas ,
mod ,
plates ,
remove ,
skid ,
tank
