Hard brakes
Hard brakes
95 F250 7.3 PSD
First time I step on the brakes they are fine. If they are pumped while coming to a stop they require a lot of foot pressure to stop. No warning lamps. Vacuum is 11" @ idle, 19" @ 2500 rpm. Vacuum stays at those values with the engine off. What should the vacuum be.
Im having about the same problem it seems... My brakes are alright the first hit, but if I tap them again they go hard, but if I increase rpms, they go softer. Vacuum pump was replaced last year, a Re-man from O'Reilly's. So im not sure what it is... I just downshift and use brakes as little as possible atm,
Spec calls for 17-21 at idle.
Go to section 06-00 -> Pinpoint Test .. scroll down to N1 - Vacuum Check on the link below.
1996 Bronco/F-Series Workshop Manual
That should lead you in the right direction.
