Porpising with 2011 F250 and trailer
I understand how ball height and hitch angle can be off some like the TT level some like it down a little in the front. But when it gets down to it, it's how much your torque on the tension bars that affect ride conditions. By measuring you can get a accurate read on how the truck is responding to the WDH, and should be done when the TT is fully loaded. Trucks that have had their suspension changed can throw a whole new monkey wrench into the problem....
Well I went for a test ride today, about 15 miles, and seems to be better with some stuff loaded toward the front.
Now I notice it more when the truck shifts gears, mainly from 4th to 5th, just that little jerk but goes away pretty quick.
Going to finish loading it up with all the camping gear then going to the scale on Monday morning, found a cement place close, and going to get some real numbers.
Thanks for all the help.
I have the F250 with the anti sway and diesel. Same exact camper and had a SERIOUS issue with porpoising on Louisiana's I-10. The highway is "bumpy" and my truck porpoised HARD for quite a while.
On my first long trip with the TT, I towed on smooth interstate without a problem. After this trip, I installed Timbren SES to help with the load.
Don't know if (1) the Timbren kit contributed to this, (2) the anti sway is braking hard with the porpoising, or (3) there is a problem with my setup.
Any thoughts?
Any thoughts?
If you are the OP, good to hear all is well now.
However, getting up to the four links would mean that I'd have to use the trailer jack to raise the front up.
I never had a light tongue so the tighter the better to level the load.
I think you need to try it both ways and "feel" the difference, both tightening the chains up and down, as well as driving to determine the proper tension.
If your load is level with the tow vehicle and adjusted properly, you will know when it's right.
INeomfd
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
20
05-19-2017 08:12 AM
astepatatime
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
17
02-21-2016 10:32 AM
FordmanNJ
15
08-30-2015 05:33 PM
