1981 F150 Carburator Rebuild
I have a 1981 F150 (ranger lariat) with a 302 (canadian model) and i need to rebuild the carburator but can't figure which kit to buy. There is no id tag on the carb. From looking at other pictures it appears to be a motorcraft 2150 without the EGR valve or float bowl vent fitting. Can i just buy a universal kit at oreillys or napa? They have many different kits? The only numbers i can see stamped into the linkage side bottome are what appears to be a 7TAKA and someone scribed a 21 on the top?
The base of the carburetor has a stamped ID number (like this: E0TF-AA for example). There's no ID number of 7TAKA, it's might be D7TF-AKA.
If you cannot find anything, I'll attempt to find the kit using the Calibration Code Parts Lists.
Hopefully, since it's a Canadian vehicle, there won't be a gaziilion different lists, like there are on US vehicles.
williamsportwrestler
26
09-24-2009 04:05 PM
theaxeman99
03-16-2002 11:07 AM
1981, 81, carb, carburator, carburetor, changing, clean, f150, ford, head, line, rebuild, trasmition, type, videos
