1981 F150 Carburator Rebuild
Old 05-09-2011, 04:06 PM
akmikek's Avatar
akmikek
akmikek is offline
I have a 1981 F150 (ranger lariat) with a 302 (canadian model) and i need to rebuild the carburator but can't figure which kit to buy. There is no id tag on the carb. From looking at other pictures it appears to be a motorcraft 2150 without the EGR valve or float bowl vent fitting. Can i just buy a universal kit at oreillys or napa? They have many different kits? The only numbers i can see stamped into the linkage side bottome are what appears to be a 7TAKA and someone scribed a 21 on the top?
Old 05-09-2011, 04:11 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The base of the carburetor has a stamped ID number (like this: E0TF-AA for example). There's no ID number of 7TAKA, it's might be D7TF-AKA.
If you cannot find anything, I'll attempt to find the kit using the Calibration Code Parts Lists.
Hopefully, since it's a Canadian vehicle, there won't be a gaziilion different lists, like there are on US vehicles.
Old 05-09-2011, 04:16 PM
akmikek's Avatar
akmikek
akmikek is offline
Thanks. I will try that number with the parts store.
fomocokid
02-23-2010 02:05 PM
williamsportwrestler
26
09-24-2009 04:05 PM
1980F15049
09-16-2007 04:31 AM
theaxeman99
03-16-2002 11:07 AM
Quick Reply: 1981 F150 Carburator Rebuild
