Noob with my first F150
Whats up guys. I'm new to the site, about 5 min new to be exact, and I just bought my first F150. It's a 94 XLT with a 5.0. It has a few issues but for the 2k I paid I think I did ok.
Issue one is the Trans will not kick down into passing gear. It up shifts fine through the gears, but if I accelerate it will not down shift to pass, even if I floor it.
The other issue is cosmetic. I want to lower the truck, but I don't want to put it in the weeds. I've found 2" shackles, but I cant find anything less than a 3" drop for the front. do they make drop springs for the front, or is 3" my only option? I like a little bit of rake to the stance.
lastly, the drain plug in my oil pan is one of the rubber compression type of plugs. I still feel threads in there but I cant tell if its been stripped or cross threaded. does anyone know what tap it take to re-thread it, and what the plug size is?
Thanks for the time
Shawn
Thanks for the time
Shawn
Lew is correct.....You actually have 2 choices...
1-Eibach/Similar brand 2" lowering Coils
2-Lightning Coils-They are 1'' lower than regular F-150 coils...
Drain plug-If you can get it out, and if the threads are fugged up, a Tap & Die set will clean them up....ANd then you can get a quick change kit....It threads in the drain plug as normal, but instead of having to remove it each oil change, simply pull an twist the end, and it'll allow the oil to drain...$8 @ O'Reilly's, etc....
Are the Lightning coils something I can get at the parts store or will I need to go to FORD?
