429 in a 78 F250
Old 05-05-2011, 01:03 AM
Bledsoe76's Avatar
Bledsoe76
Bledsoe76 is offline
429 in a 78 F250
Bought an old farm truck from friend of a friend of a (you get the idea). The truck has an old 429 out of a galaxie 500. I changed the oil and filter and put in 5 quarts. Ran it for a few minutes. Let it sit a while and the dipstick came out with 0 oil. I added a 6th quart and ran it again, let it sit and there is about an 1/8 an inch of oil on the stick. Way under ADD mark. Anyone know the length of a 429 stick from insert to tip? Im guessing this isn't the right stick. Im not very knowledgeable with engines but i know the basics. Any and all assistance would be greatly appreciated.
Old 05-05-2011, 03:29 AM
Supercab's Avatar
Supercab
Supercab is offline
Are you sure the engine is from a car? my original '78 F150s 460 took 7 quarts to be on the full line.
Old 05-05-2011, 11:03 AM
shookdaddy's Avatar
shookdaddy
shookdaddy is offline
Yea man u need to find out if someone put a trk oil pan on it they hold a lil more oil than a car pan expectially if it came of a f700
Old 05-05-2011, 08:07 PM
Bledsoe76's Avatar
Bledsoe76
ok. how would i go about finding that out. there should be a PN on the outside of the pan right? Ill check tomorrow. Its pretty dark now. Also where would the engine stamp be? I kinda wanna make sure the engine thats in it is actually a 429 and I would love to know the year of it.
Old 05-05-2011, 08:22 PM
shookdaddy's Avatar
shookdaddy
There should b a tag on the driverside valve cover if its not u might want to ask one of the other guys here. I really don't remember where mine are. But if it has a bigger oil pan u will b able to tell it will either b real wide or hang real low under ur trk.
Old 05-05-2011, 10:03 PM
Bledsoe76's Avatar
Bledsoe76
k. ill check tomorrow. Thanks.
pwjackson42
01-22-2016 10:08 AM
thelawlesslollis
1997 - 2003 F150
05-17-2015 10:22 PM
NateMack06
Modular V8 (4.6L, 5.4L)
04-23-2015 06:52 AM
JakeNail
04-15-2015 02:13 PM
1968blue
12-15-2014 03:56 PM
Quick Reply: 429 in a 78 F250
