2004 expo 4.6L P3001 Code
Wel im in a bit of distress here and im hoping that some might be able to help me out. I have a 2001 f350 v10 and i had purchased a jet power programmer. I have been saving up to replace it with a 5 star unit from mike, so to help i was going to sell my jet one to my friend that has a 2004 expedition with a 4.6Liter. We programmed his truck with no problems to the baseline 87 octane program and 2 days later he was getting a p3001 cylinder #1 misfire code. We immediatley detune it back to stock. He took it out again and it happened again. I replaced the #1 COP and checked the plug, plug was good. I know they go out once in a while. Well today he called and it did it again. Im a little worried that this jet unit (and yes according to their site is compatible) screwed up my buddies truck. and it only happens when the revs are up, say climbing a decent hill. I would appreciate any input. Thanks
Doesn't sound like it. If the Jet unit was the cause of the problem, there would be misfires on all 8 cylinders, not just one. Swap the spark plug with another and the misfire will likely go away. Just because a spark plug 'looks' good, doesn't mean it is. They do have a resistor element inside of them that can crack.
ok so i changed out the spark plug and took it for a run. no dice, the p3001 code strikes again. I brought i back and swapped the no1 and no2 fuel injectors. took it for a spin and bam no luck again. this p3001 is really getting the best of me. new coil, new plug and almost new injector. i appreciate the help fellas. unless anybody has any other cures, im gonna take it to the mechanic tomorrow. thanks again, never buying a jet P.O.S. again.
Gary Lewis
12-02-2016 04:42 PM
fredfam
12-17-2011 11:05 AM
finneys98xj
11-26-2011 11:43 PM
John TN
1983 - 2012 Ranger & B-Series
12-01-2009 03:05 PM
2000, 2003, code, expedition, intermitting, jet, marquis, misfire, misfires, p2004, p3001, power, programmer, ranger, website
