F-800 emergency brake
From what i have read about them hereon this site there is a sperate hyd pump
(commonly called a powersteering pump) mounted on the engine that needs to turn so that it can make hyd pressure to release the brakes.
The brakes I belive are spring loaded so be careful.
And why on earth did you pick F-junk for a username on this site?? some folks on here might not want to help you at all with your Fine Ford.
The following users liked this post:
IB don't have a lot of input as to which ads run here, it's up to the advertisers to specify that.
I would guess you need to trace the brake control cable down to the brake itself, and crack a fitting or two to see if you can release pressure.
OR, since I'm pretty sure these brakes are mounted to the rear of the trans, just disconnect the driveshaft.
BE SURE you chock a couple wheels BOTH WAYS before you fiddle with it.
Top answer for Ford F-800 1990 !!
Spent hours, at the house I bought it from, understanding I needed to just replace the brake line to get the emergency brake to disengage. Was locked, truck wouldn't move. Lack of documentation on the internet, and when there was, it was conflicting information just as the answers are here; I literally signed up on this forum just to tell this guy THANK YOU!!!! - @everyone UP VOTE THIS ANSWER because it's 100% CORRECT!!?? Took me 3 turns with a crescent wrench to bring the back of the bolt out just snug; fired the truck up and drove it home. Emergency Brake disengaged that easy, I hope this saves someone else time!
I got a report on this post from Nailedit1337.
If there is a problem with your own post, you can edit it.
If there is a problem with a prior post, please explain.
