1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
HOW TO REMOVE TURN SIGNAL ASSEMBLY HOUSING?
Old 05-01-2011, 05:48 PM
878ranger878's Avatar
878ranger878
878ranger878 is offline
Hey guys on my 2001 f250 XLT how do i remove the turnsignal headlight assembly. It shows to remove the two phillips headed screws between the bumper and turnsignal. I did that and its still not budging. I can see what looks like a tab. should i just pull hard and hope that tab lets go?
Thanks
Old 05-01-2011, 06:03 PM
AJB201's Avatar
AJB201
AJB201 is offline
Had to replace the one on my 99 superduty. It has the two screws along with the tabs and there are also two plastic rods that go into a rubber gasket. The do pull hard out and push hard in. Just take your time with firm pressure and it should come out.
Old 05-02-2011, 01:41 PM
878ranger878
Yep that worked, thank you so much!
Old 05-02-2011, 08:29 PM
AJB201's Avatar
AJB201
AJB201 is offline
Glad it worked for you!
Resendiz
09-06-2016 03:13 PM
fletchb
1983 - 2012 Ranger & B-Series
06-11-2016 12:45 AM
slowrollerzcustoms
07-14-2014 12:46 AM
jeff14346
01-02-2012 05:43 AM
Rusty_S
General Automotive Discussion
05-31-2010 10:29 PM
Quick Reply: HOW TO REMOVE TURN SIGNAL ASSEMBLY HOUSING?
