460 fan to close
Check the pump by trying to move it up, down, all around but usually they will leak when they start going bad. If the motor mounts are home made they may have set it to close. Take a look at the spacer between the water pump and the fan blades. Is it two or three inches long? You can get a shorter one if that's the problem.
RockWVU
12-27-2013 01:20 AM
bbf150
01-27-2009 11:10 AM
dric8792
03-23-2002 05:44 PM
