E4od Help!!
E4od Help!!
My tranny in my 92 f-150 is driving me nuts!No codes present will shift from low to 4th or may actually be 2 to 3rd lockup.Od switch functions no flashing.Can be shifted manually thru all gears.Nutty part is will function properly at times worked all the way home last night, back to work this morning till I sut it off to fuel,after restarting the problem surfaced again.
Thanks, the bad part is I work on a fleet of e450's have seen a lot of issues in the last 12 years but this ones got me stumped.I'm starting to think a wire going in to a terminal end is 1/2 broken and making intermitent connection.The stumper is no codes at all in the tranny. I remember one case where a bus would die intermitantly at stops and it turned out to be a chaffed wire that would sometimes ground out locking the converter killing the engine.This one is even more fun because it's my baby and I want it fixed. It is a $400.00 junker to most but to me it is a work truck, tows my race car, and just plain fun to drive and I will not give it up at 211,000 miles young.
