Project Sandy - Jaime's Project thread
#211
update, got the truck looking at least 10 years younger!!! got the headlamps installed today!! along with new LED lamps just need to sort the left turn signal glitch out now!
How the Lady of the family stands right now...
Was glad to have the help of a friend of mine to get them in correctly and quickly!
also got the tyres aired up proper and determined that I have an exaust leak near the engine so need to figure out if its the headers or the pipes...and replace...
#212
Your truck's looking good! It's cool that you have one that's not in need of extensive refurbishment or rebuilding! But you're taking the time to dress her up, make her more functional, and most important you're making her yours... Putting your personality into her. I like that! Keep up the good work!
One question... You mentioned in one post that you're hoping to get 550k+ miles out of her. How many are you at now? Is she already high miles or are you just hoping to keep her going for a really long time?
#213
#215
ok got another good (i think??) update, the truck we brought it home a few days ago after sitting it finally decides to at least shift to drive (and reverse) thankfully so I am able to drive it, although it will not get over 25 MPH (40KPH approx) and there is a loud wine noise, from what I am thinking is the 4x4 being engaged so not sure what or how but it feels like the manual transfer case is some how engaged and locked in place as shifting the lever does not seen to make any difference in its behavior, so I am thinking of pulling out the front drive line shaft to effectivly disconnect the transfer case from the front wheels and see if that does any thing better, at least in theory it should prevent the 4x4 from tearing its self up on the dry pavement!!
anyways once I get the transmission pulled im going to have a temp replacement put in and I will begin rebuilding the original to put back in (love having the original 230K unit in...) and I will be asking for lots of guidance from those who know what they are doing so im looking forward to this project but also kinda nerved about it as Im now venturing into new territory that I haven't done any thing with but read about!!!
so I look forward to learning and revieving some (and most likely) much needed help with my upcomming project. also planing on dropping the old leaky oil pan in favor of a new pan which if im looking at the truck correctly will have to come off to get the the transmission and get that off so I might as well get that done also!!!
#216
ok another update, got a call from the local shop yesterday which confirmed that the transfer case was stuck in 4 low, so im getting the transfer case replaced, and hopefully while im at it bring the old Tcase home and strip it down for any usable parts that I can, then once im done with that and able to pick up the truck i plan to go grab the trailer that I bought off a friend (a small trailer) so Im happy to be getting the truck back on the road
here is the new list of items to do (my to-do list)
upgrade and install LED CHML - DONE
upgrade the tail lights - DONE (finally)
repair cruise control - DONE
upgrade turn lamps - DONE
switch to all LED bulbs (interior) - IN PROGRESS
switch to all LED bulbs (exterior) - DONE
car alarm - ON HOLD
wood trim change out - IN PROGRESS
custom steering wheel (wood trim) - ON HOLD
swap out stock air snorkel to 460 snorkel - DONE
enjoying my truck - IN PROGRESS (this aint ever gonna be done...if it is please contact original poster as there may be a problem with this truck)
receive Lund Christmas gift - DONE
move spare to back end of truck and possibly add Jerry can carrier - ON HOLD
mud flaps (2 or 4) - ON HOLD
audio system upgrade - ON HOLD
custom headliner with speakers - ON HOLD
back-up alarm install - ON HOLD
window tint - ON HOLD
rear mounted spare carrier (bronco style) if possible - ON HOLD
custom headliner with speakers in it - ON HOLD
Additional stop/turn/tail LED lamps - ON HOLD
New exaust system - IN PROGRESS
topper - REMOVED
install electric fan(s) - ON HOLD
head light wire harnes to move to different switch - ON HOLD
upgrade/replace/restore headlamp lenses - DONE
Repair Tcase issue DONE
Remove air dam DONE
car alarm - ON HOLD
topper - REMOVED
Remove air dam DONE
#218
#219
#220
#221
#224
well spent the day at the location redundant center for advanced agitation and bureaucracy bureau, and spent money I really don't have at the moment renewing the trucks tags and transferring a car title to my name that my parents gave me...oh well....such is life, I hope a job comes soon....oh and getting both cars fully insured...UUUG
#225
Well we got the truck to the auto shop to get the broken transfer case out and the new one installed, work delayed due to auto salvage yard sending incorrect unit for my truck should hopefully have it done tomorrow and back home!!
Also was called and told the prospective job isn't going to happen, they decided to move with another person with more experience....oh well
