Dually Brake Drums
Old 04-27-2011, 12:48 PM
ptra2417's Avatar
ptra2417
ptra2417 is offline
Dually Brake Drums
does any one have one or a set of reasr brake drums that will fit a 1959 ford f350 dually or do you knw where i can find them
Old 04-28-2011, 05:29 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by ptra2417
does any one have one or a set of rear brake drums that will fit a 1959 ford F350 dually or do you know where i can find them?
C2TZ-1126-D (replaced B9TT-1126-A) .. Rear Brake Drum-less hub / Obsolete
Fits: 1959/66 F350 with Single or Dual Rear Wheels. There is no DRW brake drum only listed in the truck parts catalog for these trucks.
No Ford Dealer or obsolete parts vendor has any (EDIT: ditto as of 8/15/2011). This drum has been very hard to find new or used for many years.
Try: Job Lot (joblotauto.com) located in Queens NY.
Old 08-15-2011, 10:04 AM
Adrian Blanco's Avatar
Adrian Blanco
Adrian Blanco is offline
1966 F-350 Brake conversion.
Bill,
I just bought a '66 F-350 Dually and the drums are shot. As I've learned, the drums are not available. What is my best option for a transplant? Can I simply get a bolt on set-up from a newer model 350 Dually, or do I need to change out the whole rear end?
Thanks,
Adrian
Old 08-15-2011, 04:22 PM
NumberDummy
1953/66 F350's have unique 6 lug, 7.25" bolt circle wheels, so no other wheels or brake drums will work from any other year/series Ford truck.
Hemmings Motor News-Services Offered section. The are sources that take the drums, hard chrome them, then turn them down to 'standard.' Not cheap.
Consider all the 2,500 vehicles that have been made in the US since 1897. Since most are out of business now, what are peeps to do if they own a Moreland, Fageol, Stewart, Diamond T and etc if they need brake drums?
Hard chroming is the answer.
Old 08-15-2011, 10:01 PM
Adrian Blanco
I picked up a 1970's Dana 70 Dually, for $50.00 on Craigslist. Hopefully the breaks are good on it, and it will fit my truck...
Hudson High
WTB - Parts & other
10-27-2015 10:20 AM
desertbus
12-16-2012 11:20 PM
rosesrfree4u
08-27-2011 11:43 AM
michaelbrainardatwor
04-03-2010 11:17 PM
gary_b
10-16-2006 07:46 AM
Quick Reply: Dually Brake Drums
