Is Zerex G05 the way to go?
The 6.0 is known to blow head gaskets. This is why it happens. The Ford Gold coolant contains silicates. The silicates are not able to handle high EGT's generated by a good load or relatively high boost when run through the EGR cooler. They break down into a jell like sludge and fall out of suspension"
So no EGR cooler.....no problem running gold coolant right???
pop
I do not have a EGR delete but i have read somewhere with the delete the temps may go up some, i would not use the Gold junk in anything because it's only good for a max life of 50k where the ELC coolant is good for 300k before you have to even test then go another 300k why spend all the $$$$ on 8 or 10 coolant flushes or 2X that if the motor goes that long.
pop
pop
Not to mention all the friggin work involved in removing the old stuff??? No thanks
I have not had an EGR cooler for years now, did an FCDP kit...I just recently replaced the lower hose (it rubbed enough to worry me on the p/s gearbox...check yours) and did a third flush. New distilled, new gold coolant.
I'll bet my left nut, it is just fine.
No offense, but is it just me or do some people take things to another level that should never be reached?
the way I see it is no egr = no golden goo = long lived oil cooler
Ill bet your ok to
Oh brother....my EGT's (along with a straight piped 4) dropped BIG TIME! When I tow my biga$$ trailer in stock form it rarely goes above 1250*
I had a chance to look inside my manifold the other day and it is soot free and clean as a whistle, aside from the light oil mist due to my CCV not being that efficient but changing to a RACOR setup soon.
I have great respect for Ford Techs, and it only goes up as I learn more about the modern diesel engines.
I do agree that if you do not trust your local shop (Ford, Chevy, independent, etc), it is better off to do it yourself - if you have the skills.
Dieselpop, THANK YOU for taking the time to post all that information for me. Rep points given...
So, that Valvoline ELC is good to go then? I need to track down whatever I am going to use either today or tomorrow and don't know how many options I am going to have here in town. Just want to make sure that stuff is good to go.
Another question for you guys. Like I said, this job is getting handled here at the BMW dealer I work at (the tech is an ex-Ford Diesel tech and is familiar with the job). I am having him do the BP kit and I can't let this become a multi-day full-on restoration of my truck because it can't be in the shop that long. I ordered the Dieselsite coolant filter kit and am wondering if I should just fill the truck with distilled water to drive it out of the shop on Friday, and then do the full flushing at home over the weekend. It's only about a 15 mile ride home.
I'm trying to determine the best time to do the flush. I don't want to get a bunch of crap into my new parts, but as I said in my other thread- my oil cooler is already putting a little oil into my coolant. So the way I see it I have no choice but to put the truck back together with my BP oil cooler and BP EGR Cooler (didn't go delete on that for future versatility). I'm just thinking maybe I run the truck a little this weekend and do some distilled water changes on it before installing the ELC coolant. After all, the oil cooler will no longer be in contact with the coolant and I'm figuring the new BP EGR cooler will be okay. I just want to rinse things out well so I get any oil residue out of the coolant system.
I venture I would also go ahead and wait to install the Dieselsite Coolant Filter kit until after the distilled water "dumps". Does this method sound okay?
I don't know, call me crazy but after rereading the post on how to flush and clean and purify the inside of the coolant system my head started to hurt. I have one question???? Is all of this really necessary????
I do not think it is. A clean coolant system with filter and 30-50k interval changes is all you need IMO. Which is what is the OP's problem comes down to.
I have not experienced any rise in temperatures, if anything my ECT's dropped and remain constant since the EGR cooler delete.
pop
pop
There are MANY people running Ford Gold coolant that have 200k miles + on their vehicles - and never experienced the gelling.
The answer to the gelling is not so cut-and-dry as it relates to the choice of coolants.
Additionally to imply that all head gasket issues originate w/ coolant problems is also misleading. I certainly do not dissaprove of the ELC, and it may indeed be better, but the theories need to match the data (all the data).
Wrong! The egr cooler is simply a by product of the oil cooler plugging. You can egr delete and the oil cooler can and will still plug. You have eliminated the messenger not the cause.
That is not what I was referring to 69cj......I was referring to the postings indicating that the EGR is responsible for coolant degradation.
So let's say someone like me who has never flushed,and is going to do a cooler soon,what route do I go?. The restore sounds good,as does the vc9. right now I've got just distilled water in the engine,and a coolant filter.no point in antifreeze when its coming out in a week.either way,it'll be a t stat out flush.ive already drained and filled radiator twice with distilled water.suggestions anyone?.
#28
#29
I still have gold in mine ,and the shop who performed the work said that is all they have been putting back in. After forking out $4,800 in repairs I needed to get the truck out of there ASAP.
I said to the service rep (non Ford shop) about just filling it with distilled water ,and he asked me if I had a way to get all the air out of the system.
So what is up with this? Is this an issue for anyone who wants to put something other than gold in?
The truck runs great ,but I wish I could just make it go AWAY!!!
#30
I am not sure what you are asking....your post doesn't really make sense. What exactly are you looking at "getting out of there"? The air...the gold coolant????
