e4od problems on 7.3 f250 1990
Old 04-26-2011, 05:13 PM
jrb1027's Avatar
jrb1027
jrb1027 is offline
Hi i am having some issues with my truck, my e4od trans is takeing off in 3rd gear it wont shift down but jumps into neutral if you mat it and you can put it in 2nd and but not 1st. Also the overdrive button is flashing. I read that it could be the manual position lever sensor(neutral safety switch) so i changed it and i am haveing the same results. I was sure that this was the problem because i read that these mpls's go out often because of water intrusion and the symptoms were exactly what is going on. The night before i noticed it i ran my truck threw some water that definatly could have soaked my mpls.So now i am not sure what to do. THX,jake
<table align="center" border="0"><tbody><tr><td class="tborder">
</td></tr> </tbody></table>
Old 04-26-2011, 05:15 PM
snaponprofile's Avatar
snaponprofile
snaponprofile is offline
I'd take it to a place where they can read the codes or get a reader yourself.
Old 04-26-2011, 06:24 PM
jrb1027's Avatar
jrb1027
jrb1027 is offline
i think i might do that but figured i would give this a try first
Old 04-26-2011, 08:09 PM
Dark Horse's Avatar
Dark Horse
Dark Horse is offline
send me an email and I will send you a zip file on the e4od transmission. I don't know if it will solve your problem but it will be a start : KiloAlpha5RomoZuluZulu AT gmail dot com
Old 04-27-2011, 08:43 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
E4OD and problems. Those words fit so well together. I feel your pain.
Old 04-27-2011, 10:46 PM
ManicMike's Avatar
ManicMike
ManicMike is offline
If mis-maintained, then sure they'll fail. Just like anything else. Once you know the basic part's the trans uses for shift input, it becomes cake.
Old 04-28-2011, 12:24 AM
David85's Avatar
David85
David85 is offline
Check the fuses, and the main TECA relay. Sounds like its not getting 12V power.
With no electrics, the E4OD will function as follows:
4th in Drive
2nd in "2" or "1"
Reverse in R
No lockup or automatic shifting what so ever will be possible.
Old 04-28-2011, 09:35 AM
Chevy_Eater
No question maintenance will help, even a Yugo will last longer with proper maintenance. Won't change the fact it's a turd.
Been down the E4OD road before, won't do it again, either C6 or a manual in a Ford truck for me, nothing else.
Sorry to hijack though, I realize my venting doesn't help the OP any.
Old 04-28-2011, 12:56 PM
jrb1027's Avatar
jrb1027
jrb1027 is offline
i think im gonna take it to a trans shop its sounds like there could bout 3000 things wrong with it from what i have read so we will have to see what the reader says at a shop.
Old 04-28-2011, 08:32 PM
jrb1027's Avatar
jrb1027
jrb1027 is offline
i just tested the teca with a multilateral and it turns out the teca is good but i have a bad fusable link, or open or shorted wire. so where are the fuses located that i should check
Old 10-23-2011, 08:52 AM
Cyclenorthman's Avatar
Cyclenorthman
Cyclenorthman is offline
90 E4OD? or ?
Hi Folks,
I think this is my first post.I have a 90 F-250 w/7.3l/E4OD 4x4.Need some feedback on using the E4OD or using a T19 manual with 3.73 gears.
The engine is done , now for a transmission.Freedom of speech rules, but we also need freedom of information (worldwide info).
Let's hear from YOU.
CNM
Old 10-23-2011, 12:42 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
don't go back in time pre- overdrive with the T-19.remember that's like buying an appliance.the initial cost is not what gets ya.it's the efficiency rating that you look at.
this is why the E40D even at the cost of a few grand to rebuild,is much cheaper than running a c6 or 4 speed manual today @ $4 a gallon.
repair the E40D,or swap in the ZF5 if you prefer manual shift,but remember you won't have the torque multiplication of a converter,and you'll loose a little high gearing for top speeds.
Old 10-26-2011, 09:01 AM
Cyclenorthman
90' E4OD ISSUES
I know a stock 90' E4OD has issues,lube,weak parts,shift speeds ect. I am only planning on running 260 HP 7.3 IDI running it easy on the streets and some towing.Let's hear what the story is on this unit. I have been getting some feedback from rebuilding parts suppliers, but of course ,this is not complete.
Old 10-26-2011, 10:10 AM
snaponprofile
You can buy the one I have for sale if you need a good E4OD.
Old 10-26-2011, 12:32 PM
Cyclenorthman
Your post should be placed in the proper section of this forum.
CNM
Quick Reply: e4od problems on 7.3 f250 1990
