Ford 351m/400 and 429.460 bell housing depth
Old 04-26-2011, 12:56 AM
401477534's Avatar
401477534
401477534 is offline
I have been told that the depth of the bell housings on the 351m/400 is different then the 429/460. 351m/400 housings are easier to come by and i was wondering if one would bolt up to a 460, i know the pattern is the same but is the depth the same?(4 speed manual transmission.)
Old 04-29-2011, 07:52 PM
Chiefrider007's Avatar
Chiefrider007
Chiefrider007 is offline
I'm getting ready to do just that, use a 400 bellhousing on a 460. On my first attempt I found there is a depth difference, took it all back apart, and left it for a couple of years due to other projects. Since I have found that you can use spacers and make it work but I do not have any measurments made or materials selected. I need to mate them back up and see how much space there is first. I'm open to ideas and suggestions if anyone already has this info...
Old 04-29-2011, 09:15 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,596 Likes on 1,301 Posts
You should use a scattershield. That 500 horse motor, think you'll ever tear up or blow up a clutch? How fast does it rev, over 5500?
That potmetal 400 bell is just going to end up imbeded in your legs if something goes wrong.
Just a thought....
Still think a C6 is the better way to go....
Old 04-30-2011, 09:27 PM
401477534's Avatar
401477534
Just a thought....
I dont think I will find my self getting over 4500 rpm. The engine is only going to be in there for about another 9 months, then it getting a cummins swap. The c6 is shot in it will be well over $800 to get a good performance transmission built. And i can do a manual swap ford $400-$450, I just want to be able to drive it around a little longer.
Old 05-08-2011, 12:37 AM
401477534's Avatar
401477534
I looked quite a bit for info on spacing the bell housings..have not found any. If you figure it out tell me...if I find anymore info I will tell you.
Old 05-08-2011, 12:47 AM
Chiefrider007
Bolt your flywheel up get everything ready. Use clutch alignment tool bolt up pursue plate. Slide trans in till it bottoms out. Space left between block and bell housing added to a small amount is your measurement.
Old 05-08-2011, 12:51 AM
Chiefrider007
The small amount. I would slide the trans into the bushing in the flywheel and see if it bottoms out before doing the clutch. I haven't checked the books but would bet it only goes in so far.
Old 05-08-2011, 11:06 AM
401477534's Avatar
401477534
I guess thats about the only way to do it...probably the hard way, But if I cant find a 460 bell then that would be the way to go. Sliding the transmission in all the way, I would imagine back it out a 1/16 or 1/8 of an inch so the surface or tip of the shaft wouldn't ride on anything...then add that to the thickness of the spacer plate.
Old 05-08-2011, 11:38 AM
Chiefrider007
That may be in a book or limited by the pilot bearing
Old 05-08-2011, 01:38 PM
401477534's Avatar
401477534
Well, when we get to that point we will figure it out...I will go to my local salvage yard sometime this month and see if I can find a 460 bell from a truck or van, its not like a bell housing is a hot ticket item, when ever i go there the last usable parts in the truck that has been there a long time is the trans and bell.
Old 05-08-2011, 01:44 PM
Chiefrider007
Hardest to get
Old 05-08-2011, 07:24 PM
401477534's Avatar
401477534
Some vans had 460 and a 4 speed, still hard to find...i found a truck with a 460 and a 4 speed, its not in the salvage yard yet, I will see what i can get sometime this month...I might end up building the c6, it will cost around $1500 to handle my engine...I dont know yet.
Old 05-08-2011, 08:22 PM
Chiefrider007
Usually old f350 dually larger in the 70's
Old 09-10-2011, 10:25 AM
jon73's Avatar
jon73
jon73 is offline
bell housing switch
There is a spacer you can buy to allow the use of a 351m and a 400 bell housing on the 460 and 429 block it is sold by six states clutch in salt lake city
Old 09-10-2011, 10:33 AM
jon73's Avatar
jon73
jon73 is offline
cast numbers
I have a e1ta7505-aa bell housing does anyone know if it is for the 460 block or is it for the 351m and 400 block?
Quick Reply: Ford 351m/400 and 429.460 bell housing depth
