thoughts on a project 400
I've got a '77 F250 Supercab 2wd. It has a 351M right now. But I think I want to build a 400 for it over the next year. This is what I am wanting,so any advice would be greatly appreciated;
8.5-9.0 compression, this Comp cam hydraulic roller 32-411-8,5.0 lifters and spider,Aussie heads,straight up timing set(Cloyes),Edelbrock Performer w/EGR(have to pass smog),adjustable valve train w/Scorpion roller rockers,Quadrajet carb,HEI. I plan on having it balanced,block squared,align honed,what ever oil mods needed.
I am looking for drivability,torque for towing and being able to pass emissions.
The truck has a 4spd manual trans,4.10 rear gears,and I will running 235x85x16's.
Does this sound doable? Thanks
Yeah I know about torque plates. I use to work in a machine shop rebuilding engines.I have built ALOT of small/big chevys,and small fords. This is my second 400 Ford. The first one was for a '73. I did all the machine work,LPG Nylen pistons,.060 overbore,comp 268 high energy cam,stock heads,edelbrock performer intake. But before I got it together, I sold the project. I torque plate honed it,then platue (sp?) honed,balanced,polished beams on rods, ARP rod bolts,align honed,squared block. I know a little, but was mainly wondering about the combo to pass smog.....egr being functional. Thanks for the advice anyway.
On the quadrajet I don't mess with! If you know a good carb guy with what you got I think anything is possible. MSD ignition is mandatory or some type of multistrike ignition. What duration is that cam. I would assume a cam with minimal overlap is the ticket. I don't run comp cams anymore but have ran the 268 back in the day, good cam. Learned a lot for 4wds application. Minimal overlap is the ticket. getting clean air/fuel in out as efficient as possible. I pretty much use MPG heads for all my cam builds anymore, scott will fix you up if and reasonable. hope this helps! What are your NOX/CO, O2 and emmission standard/test for your area?
looked up your cam.
I did a 302 with 252hyd comp cam once. very good mileage and smooth but never tested on emmissions. 1985 ford 4wd f-150 18 mpg. My dad was a lovin it. Was lookin at pricing and I would give mpgheads a call. The tech support I get is awesome and scott is the cutter and extremely knowledgeable. Since your a ford guy he's a guy you need to know. I know their are many good guys out their but I know mpgheads is one of them especially in ford world. Pricing is about the same. Actual real world dyno time. Also on torque plate of block I belive this will help on emmissions also. Just by having the cleanest air fuel and minimal residual oil in cylinder the better. I do emmission testing on industrial engine but never our play toys. Another site to check out is www.wallisracing.com has many cool calculators on their to play with. Next question is why a quadrajet carb? I never tuned on a quadrajet much. Done edlebrock and holley types and prefer the holley types. catch you later.
