MOOG or RAYBESTOS BALL JOINTS ???
on
Hi all,
Well, my 2003 F-250 4WD has a squeaky ball joint at 51,000 miles, and that surprises me. I do plow my own driveway and my shop's parking lot, but it's light plowing.
I have been investigating ball joints, and have decided on either Moog or Raybestos (formerly Spicer). The Raybestos joints have a permanently affixed grease boot--the Moogs have a slip on boot. The Raybestos joints have no spring in them to hold tension--the Moogs do. The Raybestos joints come with a lifetime parts & LABOR warranty--the Moogs only have a parts warranty.
I know that people here swear by Moog, but has anyone here used either Spicer or Raybestos ball joints ??? I would like to hear your experience with them. They are both within $1 of each other, so price is no concern.
Check the ball joint video at
http://www.raybestoschassis.com/wps/...l/ball+joints/
RON
I've had two moog ball joints fail in a row in the past two years. They are machined with too tight of tolerances and create an issue with the steering. I have switched to raybestos and noticed they were much better quality than the moog joints, and have better "hardware" included with them
. People will claim that moog is made in the USA, they aren't. The box has china printed on it everywhere. If you research the replacement part company "OE" and use the moog lower ball joint part number, you'll find the exact part relabled as an "OE" ball joint for much cheaper. The part number stamping on the base is even in the same exact location.
I have Moog ball joints on for about 16K miles and 3 1/2 years and I'm going to replace them. Why? Because I am having a memory steer issue that I can trace back to the ball joints. They are simply too stiff and never "broke in" properly. I hate the idea of spending $350 on ball joints and seals (again) but the memory steer is significant enough that I have to do something about it.
The replacement ball joints will not be Moog. I thought about using Raybestos but I am going with the Motorcraft ball joints and seals kit from PartsGuyEd.
I think my ball joints may be squeeking also. Thought it was the suspension but don't think it is anymore. My truck is an 04' with 49k on it with the original BJ. If there are no slop in the joints I think I'm going to try to add grease fittings to them. No grease fittings pisses me off, if they had grease fittings they would probably last twice as long. If that don't work the better greasable Raybestos from Rock Auto will go on.
