at end of rope
at end of rope
I have a 1991 F-250 with 88,000 miles. I bought this from a older guy who drove it to work and home everynight. parked it one night whent out to get in it to go some place it had no reverse and neutral acted like a forward gear! the only answeres I can get from any one is tranny is junk! I can't see that not for how he drove it. any ideas?
X2 on the fluid and filter, sure helped mine out.
Received 3,108 Likes
on
when that happens with a C-6, it usually means it is time for a rebuild. the good news is that a C-6 rebuild is not that costly.
i got money that says the trans still has the same fluid and filter it was made with.
few people realize you should do a trans service every 35,000 miles. they feel if it works it is good.
x4-5... on the fluid and filter change.
I would recommend spending a bit more on some Red Line, RP, or other Synthetic ATF... Yes it will probably cost you double on the fluid but the bottom line is that synthetic fluids have higher detergency properties and will clean out your tranny of any "sticky" fluid better.
PowerstrokeRyan
16
12-06-2011 12:52 PM
KAT_Ayanami
11-28-2011 03:46 PM
psu927
08-20-2010 10:13 AM
