Where can I find the grey interior dash paint?
anyone know where I can find the dash paint so that I can touch up the damage on the 08 expedition I just got? I have called the dealership and the guy said they do not have it. Anyone paint the gray parts on their dash yet?
I have searched some websites with no luck.
If I'm not mistaken, it would also be the same paint as the trim pieces on a Eddie Bauer. I would be interested as well.
I checked the shop manuals for my 2007 and found the following reference in Section 501-35 titled "Plastics Refinishing - Interior":
Motorcraft Interior Spray Paint PM-19M547-XXXXH (XXXX=Color Code)
The color code reference I was able to find in the manuals is in the certification label in the door jamb. Labeled "INT TR". Using that, along with the following PDF will get you to the right spray:
http://www.fcsdchemicalsandlubricant...kref/paint.pdf
HTH!
[EDIT]Just a quick Google for a random can got a hit here for $13:
http://www.fordpartsgiant.com/parts/...547-2011h.html
[/EDIT]
HTH!
[/EDIT]
HTH!
PM-19M547-2011H - Ford Paint - Vinyl Renovate
[/EDIT]
HTH!
[/EDIT]
I looked on the back of the door handle piece and it says "LT STL" whatever color that is??
Matt
No, haven't ordered any of these before. It was the only thing I saw in the shop manuals.
About the only other suggestion I can think of is to check with a body shop or something. I have a cousin that works at a body shop and I will email him in the meantime and post his answer when I get it (probably be a few days).
interior paint
I know this is a little late in the game to post but i have found the place on the internet to find spray paint and the prepping stuff to paint the dash. take a look at lmctruck.com or their magazine. they have it listed in there if you know your paint code. that is found on the sticker on your driver side door or pillar. might have to do a search for your codes to find it. like mine is EH which is E is the type of seats I have and it means leather 60/40 and the H means medium parchment and medium dark parchment. lmctruck.com sells both and with the price of the two cans and a cleaner and another type of can so it can stick to the plastic with shipping my price is around $72.
I also need to touch up the interior of my 2005 f150, it is mainly black with gray accents on the dash (i need to paint the later). Color code on the door sticker is LB
I tried to find the paint on lmctruck.com but i dont seem to locate it on their catalog.
Anyone has any recommendations on where could i find a color matched paint?
I think I found a paint that is very close to the silver grey color of the dash on the Expy's ( at least on the Limiteds )
I tried it on the small triangular dash piece on the passenger side and it matched pretty good. You do have to practice spraying it to get the right texture to match as the factory finish isn't very smooth.
Matt
Matt
2013 Expedition Dash Vent Bezel Trim Paint Color
Folks,
I know it's been a while since the last post on this topic, but looking for information on a silver/gray spray paint color of interior dash components (specifically the bezel that houses the AC vents) for a 2013 expedition. I've seen many manufacturers (SEM, DupliColor) of interior paints and looking for one that closely matches what I need as described above.
If anyone had any luck with touching-up/repainting these components, I would love to hear what color was used to do so.
I appreciate everyone's help.
Many thanks,
SanMan22
Many thanks,
SanMan22
Folks,
Many thanks,
SanMan22
Many thanks,
SanMan22
iirc, those are two different and distinct options. The silver tends to peel back and expose a darker material underneath, while the dark grey appears solid colored material?
Also the bezel with the vents isn't a bezel, it's part of the main dash and doesn't really come out... meaning spray painting it without screwing everything else up is gonna be fun fun fun, and involve removing or taping up half the vehicle's interior
Maybe consider wrapping the things? Or using some kind of roll-on paint applied with a foam brush?
