I am not getting power to the fuel pump. I have checked several fuses and the one on the floorboard .Any body have an idea. Somehow this coincided with my frx and hpx mod. I am stumped and have been researching this site and haven`t found the answer. Thanks
I have an 02 and there is a fuel pump cutout switch on the pass side below the glove box on the side panel. it cuts out on impact or a very hard jolt. its a push button reset. worth checking?
Yes I put a meter on the 2 wires that attach to the fuel pump. I got no reading. I also ran 2 wires from the battery to see if I could get the fuel pump to go on and i could not.
this is a big mystery to me and I appreciate everybody`s help. I just don`t know what else to do. I will ohm the fuses tomorrow.Could it be the 42 pin connector?
If you messed with that connector then all my attention would be focused on that connector. The question I have, does any of those pins in that connector have anything to do with the fuel pump !! I wished I could help but I've never touched those UVCH or anything related to it. A bump for my question.
