Why is my truck starting hard??!!! 03-7.3litre
My truck is starting hard. Usually takes multiple tries. It almost catches and fires up but won't until the third or fourth try.
It's not throwing any codes, so I assume that all of the glow plugs are working. The glow plug relay is a month old so it can't be bad, I hope. It's belching black/gray smoke so I assume its getting fuel. I already changed the fuel filter so it is new.
Could I possibly have some rotten fuel. I also added a healthy amount of anti-gel (maybe the stations switched to non-blended, it has been chilly) So I am trying to see if plugging it in helps. Could the other fuel filter be bad, the one underneath the truck?
I'm stumped.
I'm stumped.
Try jumping the relay for the glow plugs just to make sure that's not the problem.
How many miles does it have?
Bad fuel will make it run rough, but the fact it's putting out smoke tells me the injectors are firing. Glow plugs would be my first guess. Under Valve Cover Harness is another possibility.
How cold is it?
Are you running bio-diesel? Bio-diesel has a higher cloud point than regular diesel. Even if it's cloudy, it should at least fire up. If the fuel has gelled, that will keep it from starting.
How cold is it?
How cold is it?
How cold is it?
When the valve cover harness failed the truck lurched, died and wouldn't start. Wouldn't the glow plugs throw a code?
If they are bad how do I know which ones aren't working right? I'm getting sick of throwing money at this g*ddamn truck every other month. It's just annoying little stuff but it adds up quick. I have 140k in miles
Jumping the relay??
When it starts, it runs fine. The temps are ranging from the 20-40s. Not running bio-diesel.
It needs the glow plugs at these temps.
Glow plugs will not throw a code, nor with the glow plug relay if it is bad. With the cab door open, look at your dome light. Then turn the ignition on and see if the light dims. If it does, then the glow plugs are working as well as the glow plug relay. The light should dim for a minute or so.
Jumping the relay??
Jumping the relay??
If the glow plugs are bad, you replace all of them at the same time. As for jumping the relay, do what I said above first. If the light does not dim like I said, then you have either a glow plug relay not working, or the glow plugs are bad. If the light does not dim, find the glow plug relay. Take a screwdriver (an old one that you don't care if it gets burn marks on it) and cross the main terminals with it. What you are doing is completing the circuit and bypassing the glow plug relay. Keep the terminals crossed with the screwdriver for about 30 seconds or so, (the screwdriver will get very hot) then go start your truck. If it fires right up, you've found your problem. When you change the glow plug relay, you need to make sure it has good contact where it bolts up to the bracket.
BTW, I sent a notice to a moderator about moving this thread to the 99-03PSD Forum. There are guys there that know a lot more about these engines than many mechanics. It will get a lot more attention.
I forgot about that. However it's not the amps, it's the volts. When voltage drops below 11.6 I think, the IDM won't send any signal to the injectors. But he is getting smoke out the tailpipe so it must be doing something.
I thought I was in the 7.3l forum. Crap. I love having kids that distract me.
Anyways, batteries are less than a year old and I didn't skimp. I bought Interstates. I wanted the Optimas but I couldn't afford them so I got the next best thing.
I have it plugged in now and it fires right up. I went and got some of that BG244 stuff, maybe it's just filthy injectors.
But it's still confusing the hell outta me.
But the lights dimmed like you had mentioned. I'm gonna use the injector cleaner and add fresh fuel, then drive the heck out of it.
