Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 04-15-2011, 10:22 PM
fordsrgrt fordsrgrt is offline
Garage is empty, add now
fordsrgrt is gaining momentum as a positive member of FTE.fordsrgrt is gaining momentum as a positive member of FTE.
new truck pics
thought i'd show some pics of trucks progress,getting ready for race season,had to get a 4 point cage installed to race,had it done by one of the local shops in town,.then the tank had to come out from behind seat,so got one from an 84 bronco 2 to fit between rear frame rails,then i had to install buckets in it also Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
__________________
so many chevies, so little time
  #2 (permalink)
Old 04-16-2011, 07:15 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Clearance to the rear axle looks a bit snug, but gotta do something, as long as it clears, so be it. Hadn't seen one done, always heard of doing such, thanks for sharing!
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 04-16-2011, 10:01 AM
theres 10" between the two roger,we'll see how it goes once its all back together,if nothing else i will just lower the bumpstops
__________________
  #4 (permalink)
Old 04-16-2011, 03:16 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
1967 Ford Galaxie
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
Lookin good.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
  #5 (permalink)
Old 04-19-2011, 09:32 AM
thanks,went to swap cams and valve train out the other weekend and pushrods were too short,so had to order new ones.so thought i'd tackle the cam degree and the big 11" wheel i bought was too big,hits cross member,so had to send that back and get one with the 9" wheel.last saturday if rained then turned to snow so no work on the truck outside.hey rob,need any projects to put in that nice big shop of yours
__________________
  #6 (permalink)
Old 04-19-2011, 07:42 PM
1967 Ford Galaxie
That shop is filling up fast and I haven't even brought any of my motors home yet LOL
Still got that crated A460 block and 3 FE engines at friends shops plus couple NP205s and some axles.
But if you can figure out how to get it down here I will make room and we can just have a gtg work party LOL.
__________________
Rob
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
