F*^&%$ HEADLIGHTS ARE THE DEVIL!
Old 04-16-2011, 02:00 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
Ahhhh....I see....Good thing I snatched the one outta my 94'...
-Wes
Old 04-16-2011, 11:03 AM
jodaddy's Avatar
jodaddy
jodaddy is offline
Do you have high beam switch on the floor?
Old 04-16-2011, 11:06 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Did you read post #3?
Originally Posted by SideWinder4.9l
Gonna do that today....What is up with the heating/cooling of the lights and them flickering?
-Wes
Old 04-16-2011, 11:31 AM
SideWinder4.9l
You were correct....I skimmed it, therfore didn't catch the whole thing...My bad...
Anyways....Swapped the one outta my 94' into it, and it seems to work fine now....Just don't have high/low beams.....It's showing that it has the highbeams on all the time, even when the turn signal stalk is in the low beam position....Any ideas? I wanna just straighten this issue out before the cluster bezel goes back on...
Thanks btw, White 97 xlt
-Wes
Old 04-17-2011, 09:47 AM
jk89cat's Avatar
jk89cat
jk89cat is offline
you need a multi function switch wes, do you have a spare out of your 94 you had?
Old 04-17-2011, 11:04 AM
SideWinder4.9l
had it, never pulled it though ......gonna hit the jy.....
-Wes
Old 04-17-2011, 11:10 AM
fdude64's Avatar
fdude64
fdude64 is offline
Originally Posted by White 97 xlt
A new headlight switch will go a long way on fixing this,,
You see there is a circuit breaker in a headlight switch, and they get old, the contacts in the switch get old and have more resistance that builds HEAT, that heat is making your circuit breaker go on and off....
i would bet the new switch will fix the problem
Old 04-17-2011, 11:14 AM
SideWinder4.9l
A new switch is JUST a measely $115 from NPD....
-Wes
Old 04-17-2011, 11:17 AM
fdude64's Avatar
fdude64
fdude64 is offline
sorry didnt see the second page
Old 04-17-2011, 11:18 AM
SideWinder4.9l
It's all cool man....
-Wes
Old 04-17-2011, 12:49 PM
workaholic's Avatar
workaholic
workaholic is offline
#$%^&* devil
Maybe headlight switch, Grab the switch and push on it in all different directions while the problem is occuring. Then mess with the connector plug where it plugs in (on the back of the switch) to see if anything changes.
tjmcb
01-10-2014 11:22 PM
78 & 87 Super Cab
09-13-2013 08:14 PM
JohnF350Outlaw
1999 to 2016 Super Duty
03-04-2011 03:47 PM
BlueOvalFan29
2004 - 2008 F150
08-24-2010 02:04 AM
ghunt
01-01-2008 06:45 PM
Quick Reply: F*^&%$ HEADLIGHTS ARE THE DEVIL!
