Inside Dully
I have a set of these and they really help.
Amazon.com: Camco 44913 RV Dual Wheel Valve Stem Extender for 22" Inner and Outer Dual Tire: Automotive
As the previous poster mentioned, the opening in the outside rim must line up with the valve stem on the inside wheel.
You will need a 'straight' air pressure gauge and inflator vs the little offset ones. Here is an inflator, although a bit longer than you would need. There are also similarly shaped air pressure gauges. Note that there are two different styles of ends, straight and offset a bit. Not sure which will be better.
https://miltonindustries.com/uploads...Form_9X058.pdf
horseowner
12-28-2010 03:55 PM
SHCS
11-14-2003 08:02 PM
