fuel tank switch problem
Old 04-10-2011, 04:04 PM
grizfrmmt22's Avatar
grizfrmmt22
grizfrmmt22 is offline
Unhappy fuel tank switch problem
My truck seems to have a problem, it transfers the fuel from the front tank to the rear, while the switch it on the front, but doesn't seem to be able to run on the rear tank. Is this common, what is the fix? Need to get it running quick and cheap, as it is primary transport, and i need to get feed for the horses tomorrow
Old 04-10-2011, 05:38 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,165 Likes on 920 Posts
Very common problem. The fix depends on what year truck you have.
Old 04-10-2011, 10:33 PM
kd7ptn's Avatar
kd7ptn
kd7ptn is offline
hey I have the same problem with mine. what I found out is the fuel selector. this is not an electrical solenoid but a pressure valve type. it has o-rings on the valves that swell up. as a temporary fix, i removed the o-rings. my plan is to replace this type of selector valve with a electrical solenoid type.
i would suggest to check the low pressure pump in your rear tank.
Old 04-10-2011, 11:56 PM
calmur's Avatar
calmur
calmur is offline
hi, i am having the same problem but my truck is transferring the fuel from the rear to the front. i had just changed my rear tank because it leaked and my pump went on the front tank and the cheaper fix was the tank but now i have this problem. i just lost about $50 of gas on the highway because once my front tank filled up it spilled out. how does the o rings affect this, and can these o-rings be changed.
Old 04-11-2011, 08:13 AM
subford's Avatar
subford
subford is offline
Sounds like you have a 1990 or newer truck so I would say you have a bad rear fuel pump (FDM).
Old 04-11-2011, 08:15 AM
subford's Avatar
subford
subford is offline
As you were told in your own Thread you have a bad front pump (FDM).
There are no "O" rings in it to change.
Old 04-11-2011, 08:16 AM
subford's Avatar
subford
subford is offline
That is true for a 1989 and older truck.
Old 04-11-2011, 09:04 AM
calmur's Avatar
calmur
calmur is offline
sorry to hi-jack someone elses thread. i posted hear before starting my own, but thanks for the quick replies.
Old 04-11-2011, 09:21 PM
grizfrmmt22
Thanks for your reply. Went in got feed, ran out of fuel in the front and had to siphon 5 times but horses are now happy. The Ford Dealer says the Cask for clunkers program erased any recalls on the truck (1987), the local boneyard will sell me both tank pumps and the pressure tank valve and guarantee them for $125, is better than the ford only parts which would be near 400 and the pumps about $125 each. Not cheap and a real nuisance to repair but beats the price tag the ford garage quoted. Good luck!! Wanted to put manuel valve but am told that won't work with this system. Me I wish an old 50 with a flathead 110 would run on unlead.
Old 11-30-2012, 03:27 PM
at38b's Avatar
at38b
at38b is offline
Subford, I got the same problem. I just replaced the front FDM, when running from the front it doesn't transfer, but when running from the rear it zips it on through to the front? Really don't want to change the front again.
Jeff
Old 11-30-2012, 06:23 PM
subford's Avatar
subford
subford is offline
I would say the front one is bad or more than likely it is missing both valves.
I have heard of one brand of the FDM had left the valves out of a lot of the FDM they made. This would work fine for a one tank truck, van or RV but not for a two tank truck.
When you replace it get a different brand. You should not be able to blow bad into it from either tube when you buy it.
Note that a bad fuel pressure regulator that lets the pressure go too high will blow out the valve in the non running tank also.
Old 12-01-2012, 01:56 PM
at38b's Avatar
at38b
at38b is offline
Thanks Bill for the info. 80 here today, took the new Bosch fdm out. Just got the tank back in with a new Ford FDM($$$$), works fine when the front tank is selected, when the rear tank is selected, fills the front, but not very fast. Haven't checked the return lines at the rear tank yet, or the pressure on the rail yet. The rear has been in for 16 years. Guess I can use the front tank until I get more $$$ for the rear one.
Any other thoughts on what it could be? Just got the diagnostics book in the mail, the big black one 4-1/2 inches. Maybe it will shed some light???
Jeff
lindb40530
12-27-2016 08:45 AM
Rigby
1999 to 2016 Super Duty
07-02-2016 11:17 AM
stopp429
02-15-2013 06:42 PM
predaina
29
03-29-2011 07:07 PM
biggyman50
10-12-2010 09:44 PM
Quick Reply: fuel tank switch problem
