Ok guys, I will be starting to look for a new truck. I know I have a F350 or F450 4dr cab, long bed, 4x4, 7.3L diesel, Maybe a flat bed. I plan on pulling a 3 to 4 gooes neck horse trailer and a 25 -30ft 14,000lbs goose neck trailer, for hay and moving farm equipment. That why I want a big trailer. So with that I plan on doing: gauges, chip, stage 1 injectors, 5" exhaust. I want a nice towing set up. So would I be best off with a 6sp stick trany or an auto? I will be doing most my towing in the hills around lancaster, P.A.
I take it you will be buying a '99 - '03 because you are posting in this forum. You need to check the towing capacity for the truck you look at. With what you are saying you will be towing, a F-550 may do you better.
Personally I would prefer an auto in these trucks. To me the Ford 6spds are kinda sloppy......that being said towing that much a stock auto may not last long..........but IMO a built auto with a tugged kit is hard to beat!
How old are you? Got good knees? Haha. Right now if I was to buy another truck I would try and find one with a palm shaker in it. Mainly cause it's my preference but to do alot of towing and I'd lean even more to the 6speed. So if your just wantin a vote and not opinions, 1 for 6spees!!
I value the votes and Opinions and I'm just 20! Dad owns a horse farm. And I have ok knees LOL. I a stick 18sp dump truck some times in work with a manual clutch.
From what I know that the 6 speed is really a 5 speed with low right?
So L-1-2-3-4-5 and reverse?
For towing I like the Manual but for normal daliy driving I seem to like a auto better now days maybe that just because I am getting a little older. I always liked the stick shift.
I prefer the handshaker myself . Plan on a good clutch if it hasn't all ready been done and you should be in good shape towing up and down those hills in PA. Yes your right about the 6-speed , I rarely use granny or low as you put it except with a heavy load or a steep hill from a dead stop.
After more than a million miles swappin gears and growing muscles on my clutch leg I don't care if I never shift again. I recently bought a used bug with a 5 speed only because it was a deal I couldn't pass up. Now I remember how much fun it is to start on a hill and work your way through stop and go traffic. How easy we get spoiled!
So what exactly is a BTS tranny? The trany in my 96 is starting to shift hard and slip a little.
A BTS is a trans built by (BRIAN'S TRUCK SHOP). This tranny is used in drag racing, truck pull, heavy towing trucks. Brian told me, I can't break this trans. lol
My vote is an auto with a BTS. The zf6 is pretty sloppy with long throws where you lose too much boost between shifts IMO. At least that's how my 95 with zf5 was. A good towing setup with a BTS rocks
