Oil pressure sending unit location?
Old 04-06-2011, 10:09 PM
BigBlue92's Avatar
BigBlue92
BigBlue92 is offline
Was wonderin where the oil pressue sending unit is located in a 1992 F150 with a 302. Any help is appreciated.
Old 04-06-2011, 11:10 PM
86F150302's Avatar
86F150302
86F150302 is offline
Right in front of the oil filter. Behind the AC/PS bracket.
Old 04-07-2011, 07:22 AM
BigBlue92's Avatar
BigBlue92
Alright. Will replacing this fix my oil pressure gauge? The needle on my gauge is always showing completely low oil pressure. When i take off from a stop, it moves to about mid range and then goes right back to low.
Old 04-07-2011, 09:10 AM
jas88's Avatar
jas88
jas88 is offline
Maybe. Just be aware that your OP gauge is not really a gauge, it's an idiot light. The sender is only an on-off switch that comes on at 7 psi. There is a resistor on the back of the gauge that makes it read in the "normal" range when grounded by the sender.
Old 04-07-2011, 03:41 PM
86F150302's Avatar
86F150302
It should fix it. Really no point in replacing it. Just put an aftermarket gauge in.
My stock gauge shows very low all the time but my aftermarket is at 60psi..
Old 04-07-2011, 05:04 PM
nstueve's Avatar
nstueve
nstueve is offline
or just do the conversion and jump the wire on the back of your cluster and put a real OP sending unit in from say... a 85 302... There are tons of threads on here about how to do the conversion. then you get an actuall variable pressure reading on your stock cluster guage.
Tom Callan
04-19-2016 08:30 AM
1965F100(3onthetree)
03-29-2012 11:23 AM
ARK Ranger
1997 - 2003 F150
02-11-2012 01:39 PM
drewdole
12-02-2009 11:10 PM
ledbetter
11-06-2003 01:48 PM
Quick Reply: Oil pressure sending unit location?
