quick 8.8 build question
Old 04-07-2011, 12:19 AM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
For those of you who have been into the 8.8. I know I need an inner pinion setup bearing, but do I need setups for the others or are the shims opposite of the D44 so I can press on new bearings and shim it afterward? I'd like to have the setup bearings I need made up before I pull the rear end so I don't have holdups like I did on the D44.
Old 04-07-2011, 09:15 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
The shims for the carrier are external to the bearings.They go between the outer portion of the carrier bearings and the case.
In the photo below you can see a rather thick shim sticking up on the left side between the case and carrier assembly:
Old 04-07-2011, 10:10 AM
strokin'_tatsch
Awesome. So the only setup I need is the inner pinion bearing. On my way to get a bearing now to make a setup bearing. Thanks!!
Old 04-07-2011, 11:07 AM
rla2005's Avatar
rla2005
rla2005 is offline
Good luck!
The 8.8" is pretty easy to work on. It's just a matter of having some decent tools and time. A large breaker bar or a big impact gun come in handy too
80broncoman
08-31-2007 09:33 PM
studlybilly
07-18-2004 09:51 AM
Mistro
12-10-2002 10:25 PM
Quick Reply: quick 8.8 build question
