What makes a modular engine?
Aluminum bluck only on dohc motor. Not always right but I got my info here. Modular Engines
AutoEngineLube Prelube System Reduces Engine Wear Up To 60%
has nothing to do with the engine.....engines are plain jane legacy motors....modular refers to the tooling used on the assmbely line machines that assemble the engines. the assembly line machines hare quick change "modular" to provide tooling for vaarious engine types.
so the next time you hear "todays modular engines are this and that" , not true, the engines themselves are the same legacy short blocks being produced the last few decades.
The modular engines all use the same tooling to machine them, decreasing downtime when assembling the different engines. It is simply a matter of the manufacturing process. But if you're looking for some sort of similarity between all of the mod motors, all of Ford's modular motors have a bore spacing of 100mm.
common belief.....modular is all about the tooling process...the equipment used to build the engines have modular componets....there is nothing modular on the engine themselves across the whole engine family.
