Transmission HELP for a 351 Modified
Have a 1978 Ford F-250. Had a blown 351 Modified in it. Just bought another one but the 4 speed manual transmission I had with the blown motor does not fit. It has a large Bellhousing with a large flywheel. The new motor I just bought has a much smaller flywheel. Can anyone tell me what kind of transmission I need for the new motor?
im pretty sure you said you have a 4 speed which im pretty sure they were all 435s which have a removable bellhousing. if what redsuperduty said about the 351c is true, that it uses the smaller bellhousing bolt pattern then all you should have to do is find a 435 bell that was on a 300 or a 302.
oldmansimek
03-11-2007 03:34 AM
jcwaugh
03-21-2005 07:33 AM
rk40977
32
10-19-2003 10:13 PM
