Dolphin Billet Dash Panel and Gauges
I installed the Dolphin billet dash panel and gauges into my crew. I just whipped it up there so it is not mounted the way I plan to in the long run. I also did not use the dolphin fuel gauge since it is setup for Ch*vy ohms and didn't want to swap sending units yet.
Overall I think it looks nice and the dash panel is great. The gauges seem cheap but overall I have not had issue with them. Have put a couple thousand miles on the truck since then and no issues. At night the speedo backlight does not match the other gauges which is also a downer but as far as function no issues. I bought the electrical speedo kit and calibrating was super easy and didn't require speedo gear swap to account for the 37" HMMWV tires and wheels I am running.
Is it supposed to fit behind the bezel?? I know you said you just whipped it up there, but I'm wondering if the panel will tuck behind the OEM bezel. It looks like a nice piece, but fitment would be my issue if I couldn't fit it behind the bezel like it came from the factory that way.
here is another view from Doc's ,who makes these panels. It does not appear that they fit in from behind the bezel. That was one of the questions I had.
73-79 FORDTRUCK
73-79 FORDTRUCK
LOL! I was telling my wife that if I sold my dent I would definitely lose money on it, but with my abilities I may be able to make some money selling polished grille surrounds and custom parts. Unfortunately my back is refusing to cooperate with me.
I have been looking into doing this...not sure why but I really like the gauge look...I found this on Ebay (73-79 FORD TRUCK BILLET DASH INSERT | eBay) and have been trying to get some specific specs from the seller...he is answering majority of my questions, but Tgure, what all did you have to do to get the gauges hooked up? I am really considering doing this to mine, just trying to calculate what all I will need before pulling the trigger. According to them, this one is supposed to mount to the existing back panel, and just a little modification work is required...these guys sell the set up like you have with the gauges pre-installed, but they are asking $600ish for it...my wife would shoot me...but a little here, a little there,I can get by with. Plus I haven't decided what color I want the faces in the gauges to be...just curious what all went into it, and rough ball estimate...do you have pics of the install? You can email me if you prefer Caleb_jns(@)yahoo.com...thanks again!
I did not take any install pics, but using a wiring diagram I just figured out what was what and wired it up. I was in a hurry to get operable gauges so I could drive the truck from AZ to SD so I did not take the time to make them quick disconnects which I would recommend. I actually used the Shark gauges as I couldn't bring myself to have little dolphins on them.
The kit included new sensors for the water temp, fuel, and oil pressure. It was real simple maybe took a couple hours max.
Awesome! I haven't decided if I want to go with the white background, black background, or digital readouts...what color lights are in your gauges? Another consideration...I really like the blue lighting, or even the orangish-redish colored lighting...thanks for the info, will help out tremendously...
I unplugged the instrument cluster and clipped off the plug on the harness side to connect too. As far as lights for heater controls etc it had no effect on them.
