EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Questions on Ecoboost
Old 03-17-2011, 05:55 PM
boomer08's Avatar
boomer08
boomer08 is offline
I obviously have a 2011 F-150 with the Ecoboost. Looking in the manual it shows that is takes an oil filter with the number FL-500S. After digging through some more papers in the glovebox I come across a maintenance and specifications sheet that says it takes a FL-2055 filter. Does one filter better than the other. I wonder what the difference is.
Also I want to get a fumoto oil drain valve for the truck. They need to know if the 3.5L is a 12valve or 24 valve engine. Sorry I am not a mechanic.
Old 03-17-2011, 06:12 PM
Scorpion67's Avatar
Scorpion67
Scorpion67 is offline
The engine has 24 valves, sorry I can't help on the oil filter thing though.
Old 03-17-2011, 06:14 PM
mrpositraction's Avatar
mrpositraction
mrpositraction is offline
Copied from another forum:
To:All Ford and Lincoln Dealers
Subject:EFC00063DC New Part Number FL2055, 2011 F-150 3.5L Ecoboost Oil Filter
INTRODUCING THE FL2055
Motorcraft is pleased to announce the availability of the FL2055. This all new oil filter is the service filter for the 2011 model year F-150, 3.5L Ecoboost engine.
All 2011 F-150 trucks equipped with a 3.5L Ecoboost engine were produced with a small diameter (77mm/3 inch) oil filter. The service replacement oil filter, the FL2055, is a larger diameter (94mm/3.75inch) filter. The FL2055 has significantly higher filtration efficiency and capacity than most other oil filters and is designed for added engine protection and long life. For proper engine maintenance, a FL2055 oil filter or an equivalent filter meeting Ford material and design specifications must be used.
If a replacement oil filter is installed that does not meet Ford specifications, engine damage may occur which may not be eligible for warranty coverage. The oil capacity for the 3.5L V6 Ecoboost engine with the FL2055 oil filter is 6.2 quarts (5.9L).
boomer08's Avatar
boomer08
boomer08 is offline
Thank you. I appreciate it.
Old 03-17-2011, 06:48 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,222 Likes on 804 Posts
Great find! The oil change interval is 10K miles so it's no surprise that the filter size needed to be increased.
Old 03-17-2011, 07:00 PM
NASSTY's Avatar
NASSTY
NASSTY is offline
Does it use 5W-30? Do they recommend full synthetic? I would think so with 10k mile intervals.
Old 03-17-2011, 07:46 PM
tseekins's Avatar
tseekins
tseekins is offline
According to the Ford rep that accompanied my ecoboost drive, the 3.5L requires 5w-30 MC semi syn oil. I think full syn would be a good idea but th e MC oil seems to be able to handle the job.
Old 03-17-2011, 08:41 PM
gasbrnr's Avatar
gasbrnr
gasbrnr is offline
Fumoto #F-107. I like the one with the nipple.
Old 03-18-2011, 12:04 PM
juneau76's Avatar
juneau76
juneau76 is offline
I'm a big fan of nipples (on certain things), too.
Old 03-19-2011, 08:37 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Moved to correct forum.
Old 03-20-2011, 07:53 AM
NASSTY's Avatar
NASSTY
NASSTY is offline
If I run Motorcraft semi-synthetic I'll probably stick with my usual 3k-5k mile oil changes. I'm not real comfortable with 10k mile changes without full synthetic oil. Maybe my 3k-5k mile routine will be overkill but I'll sleep better at night.
Old 03-29-2011, 10:50 PM
jimmyb08SD's Avatar
jimmyb08SD
jimmyb08SD is offline
I hear ya, I cant seem to wrap my mind around 10K intervals either!
M-S-G
22
08-15-2016 10:11 PM
MCDavis
2004 - 2008 F150
03-23-2016 09:12 PM
flixden
16
08-22-2015 10:11 AM
genovet
25
11-30-2009 09:20 AM
PartsKen
Oil & Lubrication
09-26-2009 02:08 PM
Quick Reply: Questions on Ecoboost
