Front brakes dragging - need help
82 f150 300/6
Replaced both front calipers, hoses, master cylinder, rear hose, cylinders and shoes. Drove for about 150 miles and right front brakes start dragging to the point of smoking. Left front seems to be ok. Don't understand what may be going on. Differential valve? Random bad reman caliper? Pretty disappointed after all my work. Any tips appreciated.
A few years ago I had a jeep Cherokee. Drove it 2-3 times a week to a town, 12mls there, 12mls back, no problem. Then had to go another 8 mls and front caliper drags. Had a small adjustable wrench with me so opened bleed screw, made no difference. Turned out that the caliper piston stuck when it got a little hotter in city driving. Got a repair kit snd problem solved.
In other words yours may be temperature related. Might be worth opening the bleed screw when it happens, just to eliminate restriced fluid return.
Another member (bashby) said ford had problems with their early phenolic pistons swelling when they got hot. Seems that was my problem as well. Bought some NOS motorcraft calipers from rock auto and I bet they were so old they fell under that senario. Anyway, I am planning on getting a steel piston repair kit so that should end the issue.
kincfu
03-23-2016 06:59 PM
Tim Hodgson
1978 - 1996 Big Bronco
01-19-2015 09:35 AM
Tim Hodgson
01-14-2015 06:34 AM
Truckmano5
09-06-2005 11:20 AM
