OSCAR My F350 4x4 build thread
Old 04-17-2011, 12:37 AM
75Three90's Avatar
75Three90
75Three90 is offline
danger your younger than me and dude i still do that to this day pick up a tranny onto my chest put it on the shaft slide it into the pins and bolt it up by myself but im 6'2 245 bench press 300 :P why look for a frame when all you have to do is wire wheel it brace it using 1/2in or 1/4in plate and weld it and paint it would be much eaiser and cheaper
  #62
Old 04-17-2011, 10:17 AM
fdude64's Avatar
fdude64
fdude64 is offline
i will get pics here in a bit and you will see what i am dealing with. it is the whole channel that is rusted through
  #63
Old 04-17-2011, 10:56 AM
fdude64's Avatar
fdude64
fdude64 is offline
here are some pics of my frame
this is the front spring rear hanger area
  #64
Old 04-17-2011, 11:02 AM
fdude64's Avatar
fdude64
fdude64 is offline
yes plating would be the cheaper way to go except i dont own a welder and dont know how to weld. instead of wire brushing it i would sand blast it.
  #65
Old 04-17-2011, 11:04 AM
jk89cat's Avatar
jk89cat
jk89cat is offline
holy ****! find a section of frame and fish plate it. wow i have never seen a ford frame rust out like that, ok , i have 65-68 galaxies. other than that no!
  #66
Old 04-17-2011, 11:13 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
Plating is just what it says, "Plating".....You drill some holes, and bolt it up.....I'd definantly weld it too though....A local shop could do it cheaply....
Just hop on google and look up the different plating styles....and if done properly, will last as long as a normal frame...
-Wes
  #67
Old 04-17-2011, 11:28 AM
fdude64's Avatar
fdude64
fdude64 is offline
i have had ford trucks since the early 80s mostly dentsides and i aint never seen a frame rust out like this. not to mention other than the engine oil plug all the plugs have never been out since it came from the factory. there was less than a quart in the transfercase and what came out of the tranny looked like old used motor oil. i think it set in the weeds all summer and was a plow truck at one time.
  #68
Old 04-17-2011, 11:31 AM
SideWinder4.9l
Sounds like it set a few summers..........
-Wes
  #69
Old 04-17-2011, 11:38 AM
fdude64's Avatar
fdude64
fdude64 is offline
i think the salt from the first winter is still burried in the dirt,rusted metal flakes,and road crud built up on the inside of the bottom frame rails
  #70
Old 04-17-2011, 01:48 PM
75Three90's Avatar
75Three90
i saiy find a frame in the bone yard cut it out and z it
  #71
Old 04-17-2011, 06:35 PM
fdude64's Avatar
fdude64
fdude64 is offline
what do you mean "z"it?
  #72
Old 04-17-2011, 07:43 PM
jk89cat's Avatar
jk89cat
jk89cat is offline
you cut a z shape into the good part of yours, and make a matching cut in the new section, weld in and then plate
  #73
Old 04-17-2011, 09:50 PM
fdude64's Avatar
fdude64
fdude64 is offline
ah ok i get it now. im not a welder but i found me one that does a great job for reasonable prices. im gonna take it over to him and see what he gives me for a price to repair it. if it is too high ill find a frame donor
  #74
Old 04-17-2011, 10:07 PM
75Three90's Avatar
75Three90
pretty good plan but make sure he welds with the grain on the frame not against it if he welds agaisnt it it will ruin the tempure eventualy breaking the frame
  #75
Old 04-17-2011, 10:17 PM
fdude64's Avatar
fdude64
fdude64 is offline
well he is a commercial welder that also works out of his house too. you can look at my garage photos at the spring perch pics. he done a really good job on them.
Quick Reply: OSCAR My F350 4x4 build thread
