Transmission replacement. Auto or Manual?
#31
Good guys over at valair...however, my truck breaks the clutch loose...and its stock! And i think something let go in the disk, cuz i get a jingle noise comming from it. Weird. And the throwout bearings smoked..and it had 5k on it. I'll be calling them this week. Im sure they'll help me out
#35
#38
#41
https://www.ford-trucks.com/forums/9...peed-swap.html
Some wiring stuff
https://www.ford-trucks.com/forums/1...-question.html
Another fella's swap thread
https://www.ford-trucks.com/forums/1...-complete.html
So I guess the actual answer is no, no official write up but there is some info to help. Maybe one day I could actually do a write up on how mine went anyway...
#42
#43
I thought there were only 2 variations of the zf5, one for the small blocks and one for the big blocks. Meaning you could get a donor with the 460 or 7.3? A 460 would be a lot cheaper than a powerstroke. It may be worth looking into.
#44
They come with different bell housings yes but there are also a close and wide ratio version of the ZF. I think if it has a bell housing that will bolt up then you can use either but I imiagine the wide ratio is fairly rare. Then there's either the ZF S5 42 or the ZF S5 47(96 and 97 only).
Here's some ZF info:
http://www.thedieselstop.com/faq/949...load/S5-42.pdf
jerrytown2001
16
12-27-2019 05:24 PM
CRICKEYDOG
1999 to 2016 Super Duty
02-04-2010 12:28 PM
LCAM-01XA
25
12-06-2009 09:57 PM
1972 Ford Thunderbird 429 V8
10-06-2002 11:23 AM
