Colorado Chapter Join Chapter, Leader:
Any Ford Projects?
Old 02-05-2012, 09:31 PM
jthorngate3's Avatar
jthorngate3
jthorngate3 is offline
Hey 72, I definitely am curious to see some pictures of the carb set-up you've got going on there.
  #47
Old 02-06-2012, 06:23 PM
1972-34ton's Avatar
1972-34ton
1972-34ton is offline
Carb doo-dad stack
Here's a picture out of my gallery.
  #48
Old 02-06-2012, 06:36 PM
jthorngate3
Hmmm, pretty interesting. I imagine it works pretty well though.
  #49
Old 02-07-2012, 06:31 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
I got my replacement cam today, will be putting the beast together no later than this weekend.
  #50
Old 02-07-2012, 08:22 PM
jthorngate3
What kind of an upgrade is that bump stick gonna give ya? I've been looking at some for my truck. I've been looking at some of the comp cams packages, and Clifford cam packages.
  #51
Old 02-08-2012, 09:10 AM
RIKIL's Avatar
RIKIL
RIKIL is offline
I started with a seasoned 351W block, went 030 over, used stock crank and piston rods. New heads (205cc, 2.02" intake valves), new torque converter, new pistons, custom cam. Converted from SD to MASS Air. And it's supercharged. Shooting for 500HP
  #52
Old 02-08-2012, 10:54 AM
jthorngate3
That sounds FANTASTIC!!
  #53
Old 02-08-2012, 10:30 PM
Thumper19's Avatar
Thumper19
Thumper19 is offline
Almost done going through the rear.
This is the truck
Before
After
  #54
Old 02-12-2012, 12:12 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
So far everything has been going really well. The crank end play is perfectly within its limits and so is the cam end play. All the pistons are in but one because when I was putting the sleeve on piston #3 to put it in, I broke the second piston ring so I need to try and find a new one.
The timing is set and the crank turns very smooth. I put the heads on one side and will set the rockers today. I should be able to complete one side today.
  #55
Old 02-12-2012, 02:12 PM
jthorngate3
Very nice! I've been looking at cam kits myself.
That chassis looks brand spanking new. Nice work
  #56
Old 02-12-2012, 02:55 PM
00Boss's Avatar
00Boss
00Boss is offline
Thumper that trucks lookin mean. I went and installed half of my HID kit while home and will finish it when I get back for good. I may even be lookin for a new carb while im at it.
  #57
Old 02-12-2012, 11:13 PM
muscletruck7379's Avatar
muscletruck7379
muscletruck7379 is offline
you have alot of small mods done to your truck kevin, bet they make it much more enjoyable!
can you fill me in on the "'electronic' electric-choke control module"?
love to see more pics of the interior too!
  #58
Old 02-21-2012, 09:35 PM
1972-34ton's Avatar
1972-34ton
Lightbulb Electric choke brain
Muscletruck7379:
The little electronic choke "brain" looks like a black box about an inch cubed. It has one big thick copper lug used to bolt it to manifold. (replaces a washer) There are three wires; two that energize the electric choke housing, included, and one as the input power lead. Got it from NAPA, and it solved every issue for about $80.
The choke housing works just like the original electric one.
I will edit with the P/N when I run across it. _______________
Main advantage is that it senses the intake manifold temperature, and is 'smart' enough to deal with restarts, hot starts, and rediculously low temperatures. I put it on my truck for three other reasons; the heat-stove plumbing was shot, the manifold heat-well was corroded, and I needed an idiot-resistant start-up device.
If you ever meet me, you'll understand the last part better...
  #59
Old 02-21-2012, 09:47 PM
jthorngate3
That's a pretty awesome sounding idea.
  #60
Old 02-22-2012, 09:02 AM
RIKIL's Avatar
RIKIL
RIKIL is offline
I dropped her in the other day, just need to connect a few items and see if she will start
Quick Reply: Any Ford Projects?
