6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 Belt Tensioner Replacement
Old 02-19-2014, 06:35 AM
senix's Avatar
senix
senix is online now
Received 1,420 Likes on 1,014 Posts
I'd change it too then.
Old 05-13-2014, 07:20 AM
bterry's Avatar
bterry
bterry is offline
Originally Posted by senix
This video seems misleading or at least contrary to the OP. Appears to be more by the book, than the proclaimed easy way with a 3 foot pry bar. Maybe I watched the wrong video.
Old 05-14-2014, 10:01 PM
GHeTTo JOe's Avatar
GHeTTo JOe
GHeTTo JOe is offline
thats the way i did it not too bad. i think some have said you can do it from below? i did replace both belts and tensioner i have 150k miles 4K+ hrs. ford tensioners went it great with the pin i wish all tensioners had that.
Old 05-14-2015, 07:00 PM
caddy's Avatar
caddy
caddy is offline
I replaced my tensioner from below. It was a tight fit getting to it but saved me time from removing anything else. I used a long 3/8 ratchet with a flex head to reach it.
Old 04-07-2016, 09:39 PM
bgrsk's Avatar
bgrsk
bgrsk is offline
This is more than likely the fix for anyone who has a squeak/squeal/chirping noise coming left of center on the motor. When listening and looking from the outside, it sounds like it's chirping from behind the left side of the radiator. I had read about the TSB for the idler pulley, so I did that one first(easiest). The noise did not go away. I then replaced the tensioner and belt and it's now quiet as ever, minus my 5" straight pipe
Old 02-13-2018, 05:51 PM
lcambilargiu's Avatar
lcambilargiu
lcambilargiu is offline
I think I was having the same issue as bgrsk above, except that now I don't have power steering and the batteries aren't charging. I looked underneath and as I suspected the main belt is loose, albeit not broken; something gave.
I figure it is a good idea to change the belt, the pulleys and the tensioners on this 2010 F-350 6.4 diesel. I would like to confirm a couple of things before I spend a couple hundred bucks in parts.
1. Does the AC uses a separate belt and tensioner?
2. Is the AC belt tensioner the same as the Main belt tensioner?
Thanks in advance,
Update
I found the answers to all my questions. Yes, and No, the AC belt has 6 ribs while the main line has 8 calling for a narrower tensioner pulley on the AC belt...
L
Old 02-19-2018, 10:47 AM
254XP3's Avatar
254XP3
254XP3 is offline
1. Yes the AC belt and tensioner are separate/different than the main belt/tensioner.
2. No they are not the same. You can tell if you look. The A/C tensioner is narrower.
If you are squeaking, looked for a cocked tensioner. May have to remove fender liner to get a good straight view unless you can see it good underneath. The easiest method I found to do these is pull the top half of shroud off and a long handle ratchet to release tension on belt. You will also need to pull one of the Stator mount bolts off if you are doing the A/C belt. Not a tough job, just not much room.
Old 02-19-2018, 02:39 PM
lcambilargiu
Thanks for the reply.
I have since changed the serpentine belts; the first time I've wrenched under to hood of any diesel I'm quite happy but I did manage to cut myself on the radiator so you can say that my experience was paid for in blood.
Since I was in there I changed the two belts, their tensioners and the two idler pulleys. I don't really have another diesel design as reference but I'd have to say it wasn't so easy. I can only imagine what a van would be like to work on!
The truck is back on the road and sounds so much better now. Good for another 100k I reckon.
HH65cpilot
1999 to 2016 Super Duty
07-30-2022 06:01 PM
jdemaris
15
11-05-2018 07:35 PM
PasoF450
6.7L Power Stroke Diesel
03-05-2017 04:13 AM
bigreentruck
01-26-2017 10:29 PM
mattnj
09-22-2016 09:34 PM
Quick Reply: 6.4 Belt Tensioner Replacement
