Belt tensioner & such
Decided before driving into snow country up north (Gardnerville, NV) I better change out my belt tensioner and other pulleys. Been on the list for a little while. Easy job I thought.
Turns out, there's a little keeper on the new tensioner that keeps the unit from going to the "apply tension" mode.
Installed the tensioner then went to install the new belt. Belt an inch or two to long? WT Heck?
Removed the Tensioner and had a hard look at this little rusty "keeper" holding it in the "loose belt" position.
Went at it with a flat smaller screw driver to release the "keeper". Kept fingers out of the way and watched the tensioner snap back the the tensioning position. Happens fast and Violent. Hope I didn't hurt it.
Why would they lock it in "open" position when you can't easily remove the "keeper" when tensioner installed?
Stupid engineers.
A relaxed spring always lasts longer. Like the firing pin spring on your weapon. Lasts longer when relaxed til time to use it against the bad guy.
Stupid engineers.
This right here is the correct way to release the locking mechanism on the belt tensioner. When I removed my belt tensioner 2 months ago I didn't see the locking bar on my oem belt tensioner either, it was gone. But yes, the preplacement did have one.
Stupid engineers.
Stupid engineers.
When released the spring sort of just hangs below. The last belt I did, I thought the tensioner spring was broken until I took a closer look. The lock makes it really easy to install the new belt. No need to hold the tensioner while lining up the belt with one hand. Just slide the belt over all the pulleys, take the pressure off the lock with a breaker bar, and release the lock to tension it.
Never had a clue on my two change-outs. Unsure if that's post failure and they incorporated that. But now you can honestly say you taught someone something! Thanx, hopefully next time I have to do it as I get up in years, the new owner will enjoy my/your knowledge.
Thanx for the follow.
Denny
Denny
Well, guess I screwed that up. I disabled it (broke it) and and it went in the trash. So now I have to use the breaker bar like usual to take the belt off and install it. No big deal to me. No directions mentioning that little keeper and when mounted the tensioner it didn't want to budge in either direction with the breaker bar.
Works fine still and it's a new tensioner.
lio45
12-01-2010 07:33 PM
jerrymlr1
08-19-2008 03:24 PM
